Author Topic: Quick question removing the panel round the head unit  (Read 2142 times)
Offline hatts
« on: March 22, 2013, 01:47:10 pm »
OK so as you can see from the picture I have started removing the panel. Where I have added the arrows to the picture it seems this panel is behind/under the head unit panel which leads up onto the dash where there is a air vent. Do I need to remove the air vent first? Not really sure? Help appreciated  :happy2:
MK5 Golf GTI 2008
Re: Quick question removing the panel round the head unit
« Reply #1 on: March 22, 2013, 01:54:27 pm »
Yes you have to remove the vents first to get to the screws holding the tops of that panel in place.
« Reply #2 on: March 22, 2013, 01:55:21 pm »
Yes you need to take the air vents out. There are 2 screws where your arrows are pointing.
Start at the top and work your way down.  :happy2:
Offline hatts
« Reply #3 on: March 22, 2013, 02:10:49 pm »
Thanks I thought that was the case. I did attempt this on my lunch break. But I am eager too get my RNS510 in  :stupid:
See my new RNS510 version P one year warranty for £595
« Last Edit: March 22, 2013, 04:30:20 pm by hatts »
MK5 Golf GTI 2008
Offline paulw123
  • -Receive: 47
« Reply #4 on: March 22, 2013, 03:13:40 pm »
As above you've got to work from top down.
Just watch out for those air vents. My rh one litterally exploded into its individual bits once the covering trim was prized off. I think it was damaged a bit previously, very fiddly to put back together again as the vents are'nt numbered but top 1 slightly different, must have took me 2 hours  :fighting:
Offline hatts
« Reply #6 on: March 22, 2013, 04:43:08 pm »
Thanks for the heads up. I went to Home-base today before I started removing the panel round the head unit and bought these below: I guess if I get the plastics round each side I should be able to get it out without any damage hopefully.  :scared:
This is the vent I have. Is it similar to yours?
« Last Edit: March 22, 2013, 04:45:10 pm by hatts »
MK5 Golf GTI 2008
« Reply #7 on: March 22, 2013, 07:40:14 pm »
Good video on how to do it.   :smiley:
&feature=related
Offline hatts
« Reply #8 on: March 22, 2013, 08:16:33 pm »
Getting there. Need the right torx bit though. Trip to telfords tomorrow.
MK5 Golf GTI 2008
Offline hatts
« Reply #9 on: March 23, 2013, 01:42:04 pm »
Its all plugged in and working. No damage to any panels. The only thing I forgot to put a screw back somewhere but I will put that back when I add in the Bluetooth. The only minor thing was that the FM and AM antennas dont fit on together so I have left the AM off as I hardly ever use it only for 909 once in a while but that's it.
Thanks for your help  :happy2:
MK5 Golf GTI 2008
« Reply #10 on: March 23, 2013, 01:52:39 pm »
If it's an RNS then without both FM antennas attached you wont have diversity.
Offline paulw123
  • -Receive: 47
« Reply #11 on: March 23, 2013, 02:30:37 pm »
well done.  :happy2:
oh yes what is diversity exactly?
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #12 on: March 23, 2013, 02:35:22 pm »
For the am and fm connectors you can just unclip the plastic housings and plug the metal ends in to the holes on the back of the unit. They push in tightly so won't come out - had mine like that for over a year with no problems  :happy2:
Offline Kalpsn2000
  • -Receive: 56
« Reply #13 on: March 28, 2013, 12:02:16 pm »
Yeah do this. I had mine like this for 2 years and they were fine :happy2:
Offline paulw123
  • -Receive: 47
« Reply #14 on: March 28, 2013, 12:45:31 pm »
i found that the £8 ebay adaptor also gave extra aerial length, which was usefull when fitting as the headunit can be sitting ouside and fully tested with aerials in,before pushing all the cables back into the void.
