Author Topic: Gearbox steady bar  (Read 2074 times)
Offline aledbeswick
Gearbox steady bar
« on: March 23, 2013, 11:01:56 am »
Hi,
Just had a full service on my GTi before sale, the only thing wrong is a split in the gearbox steady bar, quoted £76.83 and 3 hours labour to fit a new one. I can't find details about this anywhere. Does this sound right?
Thanks,
Aled.
MPS
Re: Gearbox steady bar
« Reply #1 on: March 23, 2013, 01:36:52 pm »
I'm guessing this is the dogbone mount. 3hrs labour sounds like a pisstake to me?
Offline SteveS
« Reply #2 on: March 23, 2013, 01:38:37 pm »
depends what bit is the problem, could buy and fit yourself... simple enough
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline Baz300
« Reply #3 on: March 23, 2013, 03:22:09 pm »
It took me 10mins to remove the Dogbone mount, install a powerflex insert and refit the mount.
Offline vRSAlex
  • -Receive: 253
« Reply #4 on: March 23, 2013, 06:24:54 pm »
Thats just to fit an insert though.  Not replace the rubbers!
Follow AKS tuning on Facebook
Offline vRSAlex
  • -Receive: 253
« Reply #5 on: March 23, 2013, 06:25:46 pm »
Hi,
Thanks,
Aled.
Sounds about right for the parts at retail.  I would have it done in an hour though all being well.
Offline phatmuther
« Reply #6 on: March 23, 2013, 08:22:09 pm »
If its this one we're talking about you can pick it up from GSF for less than £20
Shouldn't be to bad to fit.
Offline vRSAlex
  • -Receive: 253
« Reply #7 on: March 23, 2013, 10:10:41 pm »
Sounds like the op means the bush in the subframe.
Offline aledbeswick
« Reply #8 on: March 24, 2013, 06:44:37 pm »
Thanks guys,
I have had a look underneath my self, I may need to put it on a ramp but can't see anything, even the mount looks fine tbh. Will maybe speak to the garage so they can point out what they are seeing. The note on the service sheet specifically states the bar though!
Offline vRSAlex
  • -Receive: 253
« Reply #9 on: March 24, 2013, 07:52:31 pm »
Top and bottom pic of the rubber mount in the subframe shows that the rubber is badly split.  Look closely at the two rubber bars.
