Author Topic: Excel Formula - Help Please!  (Read 907 times)
Offline GE90
« on: March 23, 2013, 02:17:25 pm »
I just about have the hang of the basics, but stuck on the following!
IF CELL1 IS GREATER THAN 90    THEN I WANT THIS CELL TO BE CELL2 PLUS 15 MINUTES
CELL2 is formatted as hr:mm
Any guidance appreciated!
PS, Also stuck on calculating in a cell the hours and minutes difference (or even just minutes) between two cells set at hr:mm am/pm!
Thanks!
« Last Edit: March 23, 2013, 02:31:46 pm by GE90 »
Offline richtung
  • -Receive: 56
Re: Excel Formula - Help Please!
« Reply #1 on: March 23, 2013, 03:16:04 pm »
Im just a basic user of excel so my help will be limited.
In CELL1, i presume the value in there is a time? If so, preume the format is displayed in number of mins - so 1hr is "60" and 2 hours is "120"?
Rich
Offline chungster
« Reply #2 on: March 23, 2013, 03:42:46 pm »
Put in Cell3 00:15 as 15 mins.  Then in Cell4, enter the formula =if(cell1>90,Cell2+Cell3),0) you can replace the 0 at the end to be whatever answer you want for cell1 being below 90.
As for working the out the difference between 2 times that's in AM/PM, simply do 2nd time minus 1st time to get the difference. Then in next 2 cells, use the function =hour and =minute against the cell with the time difference. This will give you the hours and minutes in number form.
That should work I think!  :laugh:
Offline Wild Bean
« Reply #3 on: March 23, 2013, 05:09:48 pm »
Geek ! :P
Offline GE90
« Reply #4 on: March 23, 2013, 09:26:32 pm »
Thanks all, but I have completely failed!!! 6 hrs on a 'simple' spreadsheet! I have had to ask chungster whether I could send him the spreadsheet for his help!
Offline Smudgster
« Reply #5 on: March 24, 2013, 03:25:43 pm »
If you need help pm me and I will give my email address. I can sort that for you no problem but its easier to see the spreadsheet!!!
Offline GE90
« Reply #6 on: March 24, 2013, 03:29:10 pm »
Cheers, did you not get my email earlier? Thanks
