Author Topic: Audi TT by _Dejan_ (Stage 3 = 340 HP)  (Read 85808 times)
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,63938.0.html
« on: March 23, 2013, 03:23:28 pm »
Hi,
Im Dejan and I come from Slovenia. My previous car was a Fiat Stilo (1.9JTD 160HP/360Nm) and now I'm a owner of a used Audi TT mk2. I don't know how I will modify this car, but I think less than previous (Previous project can be see HERE).
Car is Audi TT MK2 2.0(FWD) S-Tronic  MY2007
Ok I will stop talking and show some pictures of my car :)
Rear badges are removed and pictures has been made before removing...
This are winter alloys:
First Im make remap...
Original:
Remapped:
Then Im change air filter...
Original:
New One(BMC Panel Filter):
And Spark Plugs to colder(NGK Iridium BKR8EIX):
Last mod which Im makd(Until now) is installing "Lower Engine Mount Insert" :)
Packed:
Lets look what is inside:
Car is lifted:
Motor protection and screw is removed, mounting location is clean:
Im use the supplied lubricant and easy push it into the hole, tighten the screws well ...
« Last Edit: November 11, 2014, 06:37:04 pm by _Dejan_ »
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
Re: Audi TT by _Dejan_ (Stage 2+)
« Reply #1 on: March 23, 2013, 03:24:24 pm »
Then Im buy new exhaust for my car. Im buy Bastuck TT/8JT-Q76E which is quad exhaust and have EC certificate...
First it was necessary to look at what Im bought :)
Then it was necessary to cut a hole in the back diffuser (Later I will make/buy carbon diffuser so this is a temporary solution):
Original exhaust silencer:
And let's cut it :)
And install a new one:
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #2 on: March 23, 2013, 03:25:44 pm »
Next mod has been new HPFP, Autotech Upgrade kit, Cam follower, RS4 PRV and build all together and install it in car...
New HPFP:
New RS4 PRV:
All items on desk(Except Cam follower):
It is time to change internals in HPFP so first we need remove stock internals:
And put inside new Autotech internals:
Then use original spring and new spring retainer:
New upgraded HPFP ready to install:
First Im prepare protective equipment:
Then Im remove HPFP fuse and "release pressure fuel" ...
Left new one right old one:
Then Im check and replace cam follower(Left old one right new one):
And new HPFP Installed:
Before upgrade:
After upgrade:
RS4 PRV I didn't install because looks to complicated and I don't have tools to do it :)
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #3 on: March 23, 2013, 03:28:49 pm »
Im also buy 70mm FOX mid/center pipe, clamps and OEM gasket :) So I will have full exhaust 70mm and downpipe 76mm
Also here is one winter picture :)
B&B Downpipe with 200 Cell Metal Cat:
200-cell metal high flow catalyst:
Clamps&reducer which came together with downpipe:
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #4 on: March 23, 2013, 03:30:48 pm »
Installing downpipe :)
First Im remove original downpipe, mid pipe and exhaust...
Then Im instal new gasket(Original Audi) and new downpipe:
Of course, not everything goes smoothly but in the end we successfully install it...
Im make one quick movie to see acceleration of my car(2 different tests):
I also have summer 18" Alloys with 245/40/18 Bridgestone Potenza RE050 tyres... Now I must upgrade ECU for Stage 2+ mods... The difference in sound is significant :)
On Tuesday I will go to make DSG Stage 1 remap...
« Last Edit: March 23, 2013, 03:32:52 pm by _Dejan_ »
Offline danishmkvgti
  • -Given: 243
  • -Receive: 155
« Reply #5 on: March 23, 2013, 03:53:11 pm »
Very good start of your modding, great looking car, what are the next things to get modded?  :smiley:
Over the top mod list ;o)
Offline valle
« Reply #6 on: March 23, 2013, 03:57:40 pm »
If u will go on stage 2+ , than u should go dsg stage 2 also, don't u think? if we are talking revo software.
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #7 on: March 23, 2013, 04:38:45 pm »
Next mods in plan is Pipercross Intake(HGHFISV01) because is only one which have EC/TUV approval(There is also KN and RAID one but both looks worse) ... After intake I will make Stage 2+ ECU remap.
Im on K03 turbo and have been told that I don't need Stage 2 DSG remap. It will be needed when I will have big turbo(K04 or GTXXXX)...
Offline valle
« Reply #8 on: March 23, 2013, 04:44:49 pm »
Hm...i was told oposit. Where did u get this informations, from revo in slovenia  ?
Great looking car u have , and some great mods- :happy2:
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #9 on: March 23, 2013, 04:47:59 pm »
From REVO:
Quote
Stage 1 DSG Software is designed to work on your car whether it’s standard or tuned regardless of the performance stage.
Stage 2 DSG Software has higher shift points in sport mode, as such is designed to work on cars with more significant hardware modifications; K04 Stage2+ or Stage3 K04 and above. If used on a car of lesser performance hardware specification the engine will take a long time and strain to reach the shift points in sport mode.
Offline valle
« Reply #10 on: March 23, 2013, 04:54:01 pm »
than , here in slovenia, they don't know what they are doing  :stupid:
thanks for the info :happy2:
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #11 on: March 23, 2013, 04:57:09 pm »
This is from offical revotechnik page ;) LINK
Offline valle
« Reply #12 on: March 23, 2013, 05:00:11 pm »
Yes i know, but here in slovenia , they said that i have to have stage 2 Dsg , on my gti ( k03 ).
Will talk to them  :stupid:
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #13 on: April 03, 2013, 07:12:20 pm »
Today Im do DSG Remap and little optimizations to ECU :)
We get this(Blue old remap, red new one):
6. gear 100km/h -> 290km/h
DSG Remap:
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #14 on: April 13, 2013, 11:35:12 am »
I see that I didn't show my summer alloys which I have on car few months :)
