Author Topic: Audi TT by _Dejan_ (Stage 3 = 340 HP)  (Read 39956 times)
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,63938.0.html
Re: Audi TT by _Dejan_ (Stage 3 = 340 HP)
« Reply #60 on: July 02, 2017, 11:29:55 am »
It is time for another small update...
Im receive some new parts...
Aquamist 4-way hex manifold:
Aquamist 1bar Checkvalve with compression fittings:
Aquamist 140cc Checkvalve jet(I will running 4x140cc in intake manifold) with 90°compress fitting:
Im start modification of new intake manifold:
Jet adaptors are test fitted and must remove them and prepare manifold to final fit and glue adapters...
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #61 on: September 03, 2017, 09:00:56 am »
Im glue adapters into manifold:
Few days before I start with summer vacations Im receive Aquamist HFS4 kit:
WMI pump:
Gauge installed into OSIR O-Pod Mono:
HFS 4 controller:
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #62 on: September 13, 2017, 08:29:24 pm »
Here is some small update :)
Because of design of dashboard air vent Im cut original to block airflow of vent which I use for gauge. Now I don't lose cooling efect on other dashboard vents ...
Blocked hole:
Gauge mounted:
And Intake Manifold prepared for install(Jets mounted and connected):
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #63 on: October 08, 2017, 03:40:35 pm »
Here is new update...
First Im modify Spulen throttle pipe pipe and add adapter for WMI jet:
Then Im remove intake manifold and install modified one:
After that Im start installing HFS-4 kit.
First Im modify original washer fluid reservoir:
Then Im prepare case for wmi pump and relay:
Connect everything together(hoses, wires to ECU):
At same time Im also install CTS Diverter Valve Kit:
Now I need to tune system make a lot of logging...
Offline Molesy
« Reply #64 on: November 23, 2017, 10:03:35 pm »
Great car and great mods, thanks for keeping us all informed on your progress!  :smiley:
Molesy  :happy2:
Offline harveym3
« Reply #65 on: November 24, 2017, 12:06:46 am »
Where did you get the dumpvalve holder mate ? I need one for my k04 conversion.
« Last Edit: November 24, 2017, 12:08:24 am by harveym3 »
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #66 on: November 24, 2017, 09:04:32 pm »
Do you think this one? LINK
Offline harveym3
« Reply #67 on: November 25, 2017, 12:35:21 am »
Cool how long did it take to arrive?
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #68 on: November 25, 2017, 10:24:30 am »
They send it by DHL and delivery from Germany to Slovenia has been in few days. Im do K04 conversion and because need DV flange Im decide to try this one instead OEM one. It fit straight without any problems.
Offline harveym3
« Reply #69 on: November 25, 2017, 12:26:06 pm »
That's cool I just can't find a standard one .
Offline _Dejan_
  • -Given: 17
    • www.carpc.si
« Reply #70 on: January 29, 2018, 09:01:03 am »
Im decide that I will sell my car... So in cca. 1 month I will put it on stock(Except intercooler, exhaust, downpipe and HPFP) and if someone is interested in some parts I will sell them seperate...
I have also avalible:
-Powerflex WALK PFF85-502G-5-AA (NEW)
-Powerflex PFF85-501-AA (NEW)
-DW65v LPFP 9-654-1025 (3 months old, used in car for 2 months)
