Author Topic: Help with Droplinks...  (Read 588 times)
Offline t20lau
    • Website design Sheffield
« on: March 28, 2013, 11:20:31 am »
Hi Guys,
Just been looking around and dont seem to be able to find what I'm looking for! Just wondering which droplinks I should purchase to replace the knocking ones currently on the car, and how difficult or easy they are to DIY? From what I understand all I require is to remove 2 18mm bolts, and them put the new ones on right? Or will I be challenged with some kind of ball joint that wont want to come off?  :signLOL:
Thanks,
Tom
SEAT Ibiza Sport | Vauxhall Astra VXR | BMW Z4 M-Sport | VW Golf GTi Edition 30 | BMW F30 330D X-Drive
Offline 56OctyVRS
  • -Receive: 72
Re: Help with Droplinks...
« Reply #1 on: March 28, 2013, 08:36:56 pm »
Just buy OE drop links and they are easy to change. You only need to jack up the car and possibly remove a wheel.
Offline Chris92
  • -Given: 33
« Reply #2 on: March 29, 2013, 12:13:57 am »
Yeah pretty straight forward to do, but sometimes the stud/bolt can turn when you try to loosen the nut. You can either grind them off or get some grips behind the bolt to stop it turning then try to loosen the nut again. Some of the drop link stud/bolts have a Torx bit in either so you can stop it turning with them
« Last Edit: March 29, 2013, 12:17:27 am by Chris92 »
Offline t20lau
« Reply #3 on: April 02, 2013, 02:26:13 pm »
Just as I fort then! I'll just order the OE ones then...
Thanks Guys :)
