Author Topic: Help needed with Xenons!  (Read 1465 times)
Offline 18Edition30
« on: March 28, 2013, 06:20:37 pm »
Right guys and girls
Had my xenons fitted today at main dealers and they have a few problems with the coding.
Apparently there version of VCDS or VagCom doesn't have a simple check box like all u guys show on the guide, they have to actually enter a code.
So they managed to get a code for xenon with shutters so they both work great but now when on high beam I have no halogen at all!? Just xenon dipped and main. So could the code be wrong? Does any one know the correct one?
Also now the leaving home light function has disappeared an just coming home is working, on the highline menu just coming home is available no sign of leaving home, a feature I really miss.
Any help appreciated.
Cheers guys
Will
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=kfuqmaei2g7m2it497g1kli6vg&/topic,19740.0.html
Re: Help needed with Xenons!
« Reply #1 on: March 28, 2013, 06:33:17 pm »
I presume they didnt wire the 2 wires into the CCM module? If not.. they have to be coded as "without shutters"
Offline 18Edition30
« Reply #2 on: March 28, 2013, 06:37:54 pm »
Yes wires in the com module fine mate, coded with shutters and they work fine, just no halogen high beam.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: March 28, 2013, 06:42:31 pm »
do you know what your original coding was?
Cluster and Key coding
Location Great Yarmouth
Offline 18Edition30
« Reply #4 on: March 28, 2013, 07:06:59 pm »
Haven't a clue mate sorry. Possible for you too code them correctly?
Offline 18Edition30
« Reply #5 on: March 28, 2013, 09:51:58 pm »
Anyone know the codes/coding to enter?
« Reply #6 on: March 30, 2013, 01:08:36 am »
The halogens shouldn't be on when full beam is selected.
The halogens only operate as flash to pass lights.
Offline Luka
« Reply #7 on: March 31, 2013, 10:45:31 am »
When I coded mine with halogen as flash to pass, the halogens came on with xenon high beam shutter. If I coded out the halogen flash to pass, they didn't come on with high beam. I couldn't get halogen as flash to pass but not on high beam.
Sold - 2006 Tornado Red GTI 3dr
