Author Topic: Measuring resistance  (Read 705 times)
Offline Meallbhan
« on: March 30, 2013, 01:07:20 pm »
Does anyone know what the resistance value should be on the coolant temp sensor when taken out the car? Part no 06A919501A.
Offline Meallbhan
Re: Measuring resistance
« Reply #1 on: March 30, 2013, 06:55:47 pm »
Anyone?
Offline Meallbhan
« Reply #2 on: March 31, 2013, 06:42:40 pm »
If no one knows this, is there anywhere someone could suggest where I can look that may help me find out?
Offline olufsen
« Reply #3 on: March 31, 2013, 06:52:38 pm »
I don't matey... however if it's of any help, it's a very cheap part that can be replaced for about a fiver.
Offline Meallbhan
« Reply #4 on: March 31, 2013, 07:02:19 pm »
Thanks mate, yeah its a cheap part but nearer 20 quid which is still ok. I just replaced the one above the gearbox and I have the same problem, the thermostat has also been done which only leaves the 2nd sensor to check (which I can't find). This leads me to believe the 1st sensor still works and the 2nd is dodgey. But they could also both be dodgey. I just want to see if I can test the 1st one before buying another.
Offline olufsen
« Reply #5 on: March 31, 2013, 07:19:13 pm »
I only said a fiver cos they seem to be about £7 on fleabay.
I hear you mate, fault chasing is a bitch... can you scan the car, it may nail down the issue for you.
Good luck mate! :happy2:
Offline Meallbhan
« Reply #6 on: March 31, 2013, 08:35:33 pm »
I had the car scanned and is showing no fault codes just now, typical eh.
