Author Topic: Rubbing issues with BBS VZ and 996tt brakes...  (Read 2668 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: Rubbing issues with BBS VZ and 996tt brakes...
« Reply #15 on: April 13, 2013, 12:06:10 pm »
got 3mm tpi spacers on yesterday and hoping this will have solved the issue.
so for anyone wanting to put these brakes on with vz you will need a spacer if you have TT arms fitted, but if you have the Gti arms you will probably get the BBK under the VZ with no spacer a la QD (MBE)  :happy2:
TT arms does absolutly no difference regarding spacer/brake-wheel clearance.
They are only an issue regarding clearance between tyre and front wing/fender  :happy2:
sorry, my problem was twofold - rubbing with a 10mm spacer and not clearing the brake caliper with no spacer, the 3mm spacer has solved both issues  :pomppomp:
 :drinking:
Over the top mod list ;o)
