Author Topic: Quick Wiring Help?  (Read 519 times)
Offline Johnny_tro
Quick Wiring Help?
« on: March 30, 2013, 09:21:31 pm »
I'm putting a DVD player in to the rear (for little ones) I just need someone to advise me......
Unit has.......
Red wire
Black wire
Yellow wire
I want to connect this to the 12v ciggy lighter in the rear, it does not matter about having a perm live feed. I tried connecting this earlier and popped a fuse. Am I right putting the red to 12 ciggy lighter and grounding the black?
Offline Squeeguk
Re: Quick Wiring Help?
« Reply #1 on: March 30, 2013, 10:04:43 pm »
The wiring is as follows on those:
Red - 12V+ Switched
Yellow - 12V+ Constant
Black - Chassis ground
What rating is the fuse you blew? IF you are drawing too much current quickly, it will pop low rated fuses. Perhaps run a wire from the the fuse box. Either that or the unit might be faulty.
