Author Topic: mk5 issues  (Read 1080 times)
Offline torque777
mk5 issues
« on: March 31, 2013, 08:02:53 am »
I'm having issues with my door locks on my mk5 ..sometimes they unlock other times you have to keep pressing the remote as one door or snother just won't open ....this is a random fault but annoying ....my car is a mk5 variant 2008 with 34000 on her ...anyone else had door lock issues ????
Offline percy
Re: mk5 issues
« Reply #1 on: March 31, 2013, 08:23:44 am »
 Have you changed the battery in the remote?
Offline Stg123
Re: mk5 issues
« Reply #2 on: March 31, 2013, 09:01:38 am »
Sounds like the problem I have with my 5 door. I had it scanned and the results were that one rear locking control module thing was showing implausible and the other was showing intermittent. Basically one is knackered and the other is nearly knackered. I am having both replaced. This seems to be a known if not too common problem/ issue with the mk5. Have a bash with the search function and you will find a few threads dealing with this problem. My advice is to get your car scanned to see if the problem is one of these pesky control module thingies. Good luck
Offline torque777
Re: Re: mk5 issues
« Reply #3 on: March 31, 2013, 09:26:32 am »
Thank you ....was hoping not to change them as they aint cheap even with discount at tps
sent using my own fingers
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: mk5 issues
« Reply #4 on: March 31, 2013, 03:08:29 pm »
Check the wiring first. The ones in the rubber boot between the door and car-these can get damaged with the constant opening&closing.
'07 Red manual
Offline torque777
Re: Re: mk5 issues
« Reply #5 on: March 31, 2013, 03:22:56 pm »
Thanks will check these also
Offline Stg123
Re: mk5 issues
« Reply #6 on: April 11, 2013, 04:43:02 pm »
When you lock the car does the led in the door card flash quickly and then go solid red for 30 secondsish and then start the normal blinking? The solid red is an indication there is a fault with the locking system. It should (as mine does now) flash quickly for a couple of seconds and then settle into the regular slower flashing. Have you got the problem sorted yet?
Offline torque777
Re: Re: mk5 issues
« Reply #7 on: April 11, 2013, 04:52:40 pm »
I don't think it flashes any faster than normal ? Tbh its getting worse ...been looking on ebay at new door modules but they are not genuine at £44 but am wondering how good they are as it will save me some cash lol ....it sounds slow and lazy compared to all the other doors ?
