Author Topic: RNS 510 Version B Sat Nav Not working GPS CURSOR DOES NOT MOVE  (Read 1525 times)
Offline Usual Suspect
Hi everyone
My Sat Nav RNS 510 Version B is playing up
Everything works as it should accept for the GPS
The problem I am having with the GPS is that it is not guidin me anywhere and thinks that I am in a differnt country
I have tried a new GPS  aerial on it and have even positioned it on the roof however it does not Pick up any Satellites
On the secret menu when u hold setup down it says the GPS antenna is connected and VCDS scan shows no faults found
When on the map screen It says No fixed found and 0 out 0 satellites
The GPS Cursor also does not move at all
Anyone have any ideas and now off a fix?
Many thanks
Offline alexperkins
  • -Receive: 99
Re: RNS 510 Version B Sat Nav Not working GPS CURSOR DOES NOT MOVE
« Reply #1 on: April 01, 2013, 02:38:23 pm »
Have you tried updating the firmware on the unit?
« Reply #2 on: April 01, 2013, 03:29:04 pm »
Yes I have current for aware is 2760
Could it be bad firmware?
Many thanks
Offline alexperkins
  • -Receive: 99
« Reply #3 on: April 01, 2013, 03:29:32 pm »
Quite possible
Upgrade it to 3810
« Reply #4 on: April 01, 2013, 04:29:47 pm »
Thanks will try that
Anyone have the link to download 3810 software?
Also will it work on mine as it is a revision B?
Many thanks
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: RNS 510 Version B Sat Nav Not working GPS CURSOR DOES NOT MOVE
« Reply #5 on: April 01, 2013, 04:41:47 pm »
Might need newer maps too
Sent from my GT-I9300 using Tapatalk 2
Offline jbc
« Reply #6 on: April 01, 2013, 05:21:32 pm »
Many thanks
Fairly sure the link to firmware version 3810 in the tutorial sticky on this page of the forum still works as I downloaded it from here recently.
http://www.mk5golfgti.co.uk/forum/index.php/topic,23779.0.html
2012 Mk6 GTD. Tornado Red. TPMS, RNS510 and reverse camera retrofit.
