Author Topic: Anybody know the part # / price for Xenon washer bottle  (Read 1221 times)
Offline olufsen
« on: April 01, 2013, 06:19:18 pm »
Mine is leaking :(
Offline olufsen
Re: Anybody know the part # / price for Xenon washer bottle
« Reply #1 on: April 01, 2013, 06:46:58 pm »
IS this ok for Xenon's?: 1K6 955 453 H
Offline skard
  • -Receive: 245
« Reply #2 on: April 01, 2013, 09:20:35 pm »
My receipt is long gone but I think it's 1K0 955 453 S - try TPS or the dealer to confirm it is the 5.5L version
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: April 01, 2013, 09:22:37 pm »
I have a 5.5 ltr bottle, you would need to make the hole for the washer sensor and headlight washer pump
my bottle is
1K0 955 453 Q
1K0 955 453 R
1K0 955 453 S
« Last Edit: April 01, 2013, 09:30:14 pm by Eddie-NL »
Cluster and Key coding
Location Great Yarmouth
Offline simonp
  • -Receive: 38
  • No longer a Golfer
« Reply #4 on: April 01, 2013, 09:23:13 pm »
Dunno about the bottle, but the pump is nearly 60 quid. I know this from when a fox broke mine in half with his head!
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #5 on: April 01, 2013, 09:24:55 pm »
ETKA's showing the S revision as 5.5LT, and the H revision as a 3.6LT
So "S" it is  :happy2:
£40.46
Offline olufsen
« Reply #6 on: April 01, 2013, 09:29:14 pm »
Cheers guys, tbf, I haven't fully investigated the problem, but it's definitely leaking from the the offside front (Not majorily but certainly some), been doing it for a couple of weeks (not coolant / brake fluid / oil).
Is it front bumper off to swap out.  I'm hoping it's the bottle / pipe - no VCDS error messages so assuming not the pump.
@ Eddie; What's the score with having to make new holes for the bottle mate, is that a standard requirement, or do you have a slightly different version..?
Edit:
@ Skard and Freddy, cheers mate, really helpful that :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: April 01, 2013, 09:34:06 pm »
It depends on what equipment is fitted
the bottle is the same
Screen washer
Screen washer & Level sensor
Screen Washer & Level Sensor & Headlight washer
Offline olufsen
« Reply #8 on: April 01, 2013, 09:44:35 pm »
Cheers mate, but now I'm confused lol (doesn't take much).
What's the point in the three different model numbers for the 5.5L?
5.5L Washer Bottles
1K0 955 453 Q
1K0 955 453 R
1K0 955 453 S
Does that suggest that the "S" variant has pre-cut holes for Level Sensor & Headlight washer?  If so, I'd be grabbing that one to save hacking at it.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #9 on: April 01, 2013, 10:01:34 pm »
the S version probably does come with the holes pre-done
my bottle has all 3x part numbers on it, as would they all
