Author Topic: New car but only one remote lock fob works.  (Read 1792 times)
Offline hakko
« on: April 02, 2013, 07:40:51 pm »
Hi Guys,
After buying my car (Year 2007) I noticed that the spare key fob doesn't work. I can use it to manually lock/unlock but not via remote.
This means that if I lose the main key, which the car has been locked with via remote (and alarm armed) then I won't be able to disarm the alarm.
I've had a quick look online and couldn't get any of the guides to work. I have also just replaced the battery, in case.
Is it possible for me to pair the fob to the car or must I bring it to a main dealer?
Cheers.
Offline bower
Re: New car but only one remote lock fob works.
« Reply #1 on: April 02, 2013, 07:44:07 pm »
this is maybe not the same for u but i bought my car last week and only one keyfob worked but as it turned out it was just because the 2 keys were too close to each other  :stupid: once separated all was ok
Offline skard
  • -Receive: 245
« Reply #2 on: April 02, 2013, 07:48:34 pm »
I once had a fob lose sync then refused to resync even though the red LED worked.
You can quickly resync it to your Central Convenience Module if you can get a hold of someone with VCDS.
Offline hakko
« Reply #3 on: April 02, 2013, 07:53:14 pm »
Hi,
That's an interesting solution, but not working for me i'm afraid. :(
Offline skard
  • -Receive: 245
