Author Topic: ABS + ESP lights both showing, vag-com in Brum ?  (Read 546 times)
Offline Digger3
« on: April 02, 2013, 07:46:11 pm »
OK as it says in the title really  the ABS  ESP & tyre-pressure lights came on today, turned the ignition off re-started the car lights cleared, drove about a mile and they came back on again.
The ESP light hasn't come back on driving home from work but the ABS as stayed on for a short distance,now there clear again any ideas, I'm in Brum if anyone can help with VAG-COM ???      :smiley:
« Last Edit: April 02, 2013, 10:19:52 pm by Digger3 »
3DR GTI, Black Magic, Factory Fitted Winter-Pack, Lux-Pack, Colour-Coded Rear Valance, Otherwise Totally Standard, For Now.....
Offline webby888
Re: ABS + ESP lights both showing, vag-com in Brum ?
« Reply #1 on: April 02, 2013, 11:06:29 pm »
this happened to me
needed a new wheel bearing and speed sensor. Had it fixed at an indie for £340 :(
Only annoying thing is that it now happens again so i think another wheel has gone!
« Reply #2 on: April 02, 2013, 11:32:40 pm »
Offline Digger3
« Reply #3 on: April 03, 2013, 12:47:43 am »
Thanks ,I've mess,    Stealthwolf...
Offline Digger3
« Reply #4 on: April 03, 2013, 07:41:03 pm »
all clear for about 8 miles on route to work this morning, went over a small bump in the road and all three lights back on  :confused:
If anyone has any ideas or have had similar symptoms please share,,,  oh and still need someone with vag-com local to brum  :notworthy:
Offline Digger3
« Reply #5 on: April 07, 2013, 08:15:49 pm »
 Bump !
Offline Kemnaychris
« Reply #6 on: April 07, 2013, 08:29:25 pm »
I had same issue was a rear bearing and abs speed sensor I was 41 for sensor and 68 for rear bearing then 30 to fit so not bad at all :-) still got ESP tho :(
2005 blue gray 140 gt tdi
