Author Topic: Diverter Valve Rev G or D?  (Read 38707 times)
Offline dan_gti
« on: April 02, 2013, 11:42:27 pm »
I apologise as i know this has probably been solved many times before.
I have a stock mk5 gti which I am planning on having remapped. In preparation I have ordered a Pipercross panel filter and plan on removing the pre-cat from the DP.
Finally I wanted to make sure I had the correct diverter valve in place. The photo below is of my diverter valve which I believe is a rev G?
Is this the most recent revision or should I change to the rev D valve with the piston?
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
Re: Diverter Valve Rev G or D?
« Reply #1 on: April 02, 2013, 11:46:34 pm »
That is a revision G. The part number is the second line of text and the revision letter is always at the end.
Don't bother with the rev D.
'07 Red manual
Offline Simon_2.0t
« Reply #2 on: April 02, 2013, 11:58:54 pm »
Heard and read lots of reviews that G is the one to go for, including Nick at R-Tech. Out of interest how did you find locating it? Front wheel off job?
Si
Offline olufsen
« Reply #3 on: April 03, 2013, 05:40:37 am »
Have D ATM but want to try G, when I can be bothered to lift the car.
If your G has been in a while it might be worth taking off to inspect or replace...
Offline dan_gti
« Reply #4 on: April 03, 2013, 07:48:22 am »
Si
Just jacked the drivers side of the car up, put a stand under wishbone, got under car from front and it's located just behind the driveshaft. Looks tricky to remove purely due to inaccessibility.
Offline dan_gti
« Reply #5 on: April 03, 2013, 07:50:28 am »
I'm thinking I probably will take it off to inspect it. Just wondering what the benefit would be of having G over D as I believe the rev D is the most up to date and robust revision?
Saintsteve
« Reply #6 on: April 03, 2013, 08:05:57 am »
Wrong..it's not the the most up to date. It's not fitted to the 2.0tfsi. G is the correct version to fit.
Offline olufsen
« Reply #7 on: April 03, 2013, 08:51:53 am »
D is the most expensive, but have been known to leak from new, G seems the best all round, but will need replacing at some point.
Offline dan_gti
« Reply #8 on: April 03, 2013, 01:06:41 pm »
Think i'll just order a rev G then and replace it anyway as the car is almost 5 years old now. Saves taking it apart to inspect and finding it's knackered and having to refit it.
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #9 on: April 03, 2013, 09:44:59 pm »
I've tried both D and G, personally prefer the rev G. My car doesn't seem to like the D, doesn't feel smooth upon gear changes, like it's sticking or something...
Offline Welshman Adam
« Reply #10 on: April 11, 2013, 04:31:53 pm »
So what would have been on the car from new?  I have a 57 plate ED30.  In other words, were any supplied with the Rev G fitted?  Or was this a post production upgrade issued by VW for DV failures?
Black ED30 No. 1,328 - Gone but not forgotten...
Offline darren4
« Reply #11 on: April 11, 2013, 05:21:52 pm »
I went to change my gf's dv and it was a rev g fitted. This was on an 08 ed30  :smiley:
Offline greygti
« Reply #12 on: April 11, 2013, 08:55:41 pm »
G
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
« Reply #13 on: April 11, 2013, 09:00:10 pm »
« Reply #14 on: April 12, 2013, 02:25:19 pm »
Ah, OK.  So a mod I thought I needed that I actually don't.  Result!
Thanks all.
