Author Topic: For those who have fitted a rear view camera  (Read 938 times)
Offline Matto
  • -Receive: 116
« on: April 03, 2013, 06:59:59 pm »
Just wondering who on here has fitted their own RVC? I have just bought one and wondering if there is anyone localish (Derby) who has experience in doing this. I have read the guides on here and on my-gti but not sure I want to go it alone. So looking for someone who can fit or who can advise really.
Thanks in advance.
Matt
Offline Dannyboy88
Re: For those who have fitted a rear view camera
« Reply #1 on: April 03, 2013, 07:38:36 pm »
Helped a mate fit a OEM one in a b6 passat estate and it was a right pain in the arse, not a job to be done alone, hope you find someone to help you.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: April 03, 2013, 10:12:26 pm »
it is fairly easy, wiring depends on the kit you have
i made a plug and play on mine, apart from the 12v from the fuse box
other require joing into the reverse light wire
Cluster and Key coding
Location Great Yarmouth
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #3 on: April 03, 2013, 10:39:25 pm »
Matt,
Go for it mate, if i can do it anyone can  :signLOL:
Just take your time, give yourself a full day and away you go.
SteveP's guide is excellent, i also used this aswell as it has different detail at different points
http://www.myturbodiesel.com/1000q/a6/backup-camera-golf.htm
Hugely satisfiying once completed  :happy2:
Offline Luka
« Reply #4 on: April 03, 2013, 10:44:34 pm »
Don't mind lending a hand Matt. Just done OPS so can't be too difficult.  :happy2:
Sold - 2006 Tornado Red GTI 3dr
Offline jbc
« Reply #5 on: April 03, 2013, 10:56:29 pm »
Matt,
I also recommend this guide as well as SteveP's guide. The above guide makes it much easier to understand the rear c pillar trim removal, which otherwise can be tricky because VW have hidden a couple of the fixing screws in places you would never look without this guide.
2012 Mk6 GTD. Tornado Red. TPMS, RNS510 and reverse camera retrofit.
Offline Matto
  • -Receive: 116
« Reply #6 on: April 04, 2013, 07:25:51 am »
Thanks for the reassurance and the extra guide. I hadn't seen that one before. Hopefully should be ok if I take my time.
Luka, cheers mate. I might drop you a message when I get some spare time to fit it  :happy2:
