Author Topic: Terraclean  (Read 8924 times)
Offline Rustybear
  • -Given: 243
Re: Terraclean
« Reply #15 on: April 06, 2013, 11:35:03 am »
All i know is that it works!!!
 Had it done in Bridgend.
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: Terraclean
« Reply #16 on: April 06, 2013, 11:57:22 am »
We should keep this thread open for anyone else who has taken the challenge.
Will get mine done around the time of my nexr service.
Sent From My Samsung S3
Offline ArildStavrum
Re: Terraclean
« Reply #17 on: April 06, 2013, 12:47:24 pm »
There is a garage near me in Hammersmith that does this.
I have a neuspeed CAI but think I read somewhere that this causes a problem or could cause a problem when going through the terraclean.
Is that nonsense?
Saintsteve
Re: Terraclean
« Reply #18 on: April 06, 2013, 05:30:31 pm »
Is this not all a waste of time (and money) with direct injection?
Erh no, because these cars still produce carbon from exhaust gases :signLOL:   :confused:
Saintsteve
Re: Re: Terraclean
« Reply #19 on: April 06, 2013, 05:31:13 pm »
I did and posted around a month ago :happy2:
northyracing
Re: Terraclean
« Reply #20 on: April 06, 2013, 06:51:59 pm »
So does this get injected into the inlet manifold via where the PCV hose goes then does it find its way into the valves
Saintsteve
Re: Terraclean
« Reply #21 on: April 06, 2013, 07:06:24 pm »
No.. As I've explained to you, it doesn't. Combustion side and exhaust and cat only, along with fuelling.
You need either a can of sea foam or Wynns EGT spray that I keep suggesting to you, and have Terraclean do the rest. That's of course after an emissions tests confirms your issue :wink:
northyracing
Re: Terraclean
« Reply #22 on: April 06, 2013, 07:11:04 pm »
I done the spray into the inlet manifold the other day does this go into the inlet valves or not or is it only through the MAF side that reaches the inlet. When I did this a little black soot came from exhaust but was perfectly clean after a few minutes so has what I done had no affect the the valves
Offline Panthera
Re: Terraclean
« Reply #23 on: April 18, 2013, 06:25:30 pm »
I am very tempted to get this done as a few colleagues have had this done on their Impreza WRX STi Prodrive and Zafria 1800 and they have both said how good it is and what they are now noticing  - smother, more refined and more poke, not to mention better mpg. The guy with the Zafria has gained 6mpg.
The colleague with the zafria goes home the same way as me and last night he was behind me and as I went to over take the car in front of me, he noticed a small puff of dirty exhaust gasses come out of the exhaust as I floored it.  I have noticed that after I have cleaned the car inc exhaust, and driven  30 miles, the tips of the exhaust are dirty.  So was wondering if terraclean might rectify this?
2007 Blue Graphite Golf GTi
Offline Panthera
Re: Terraclean
« Reply #24 on: April 18, 2013, 06:28:40 pm »
Had it done WOW!! Can feel the difference in performance.
Car has 100k on so needed a good clean out inside and boy has it done that..
Glad you've noticed the difference aswell. It might pay you to do the inlet valves aswell via the Maf housing as the Terraclean won't do this, or did they put a different machine on the car to carry out an Intake clean.??
I done both and car runs alot better, and that Carbon buildup causes these getting more common idling issues as the mileages rank up.
By using what method, product?
Saintsteve
Re: Terraclean
« Reply #25 on: April 18, 2013, 08:45:26 pm »
Terraclean have an intake cleaning kit for direct injection cars, but as yet dealers do not stock it to offer, just make excuses that the Black can will sort the inlet valves out when clearly they won't.
Offline Craigh1983
    • Leicester Wedding Photographers
Re: Terraclean
« Reply #26 on: April 18, 2013, 11:17:44 pm »
Hi Steve,
I have a can of wynn's egr cleaner I am wanting to use. Do I need to spray this into the air intake pipe at the back of the engine? The one that was attached to the engine cover and maf?
Saintsteve
Re: Terraclean
« Reply #27 on: April 19, 2013, 05:31:03 pm »
Hi Steve,
Via the MAF is one route, but the most direct is remove the intake temperature  manifold sensor.. Or another way or most easiest..is if you can do it like i did the 2nd attempt, is to release the pipe from the PCV to the air inlet manifold, without fully pulling it off, spray contents around the o ring of that pipe whist your keeping revs under 2000rpm, if you remove it too far, the engine will stall.
Slowly spray in every 10 seconds or so till contents of can is empty .
« Last Edit: April 19, 2013, 05:32:34 pm by Saintsteve »
Offline Squeeguk
Re: Terraclean
« Reply #28 on: April 20, 2013, 10:42:13 am »
I know this is not a direct injection engine, but my brother had his wife's Jeep 3.7 V6 done yesterday and was so impressed with the difference, he's booked his Astra in for Monday to get done. His wife's Jeep has 42k miles and is a 2006 model, so was probably nice and coked up.
Offline bushypad
  • -Given: 18
Re: Terraclean
« Reply #29 on: April 20, 2013, 03:58:06 pm »
Gunna get this done my mk5 gti has done 72k im sure it could do with a clean! Anyone know if any reputable dealers in yorkshire?
