Author Topic: removing super glue  (Read 1149 times)
Offline DSG_Steel
removing super glue
« on: April 06, 2013, 12:47:26 am »
Hi
what can I use to remove super glue on my rear boot hatch?
 as somebody has super glued the gti badge on and I want to de badge it
Billy
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=l5l4i9vnenv60ah8n95ln1jdkp&/topic,19740.0.html
Re: removing super glue
« Reply #1 on: April 06, 2013, 12:49:25 am »
Superglue? on the paint? Youll have a job, as it will have 'burned' the paint  :sad1:
Offline xjay1337
  • -Receive: 377
« Reply #2 on: April 06, 2013, 12:59:03 am »
Yeah, you won't get it off.. it would have likely ruined the laquer. If you really want to try, you could give it a going over with a machine incase you are lucky... but if you are inexperienced and the laquer has peeled or been "burnt" then you could make things worse..
I would simply sticking a GTI badge on again and wait until you can have the boot resprayed (I'm sure a "smart repair" would do the trick but the quality is always hit and miss).
Offline DSG_Steel
« Reply #3 on: April 07, 2013, 01:57:13 am »
Thanks for hepling..I might just have to put the badge back on
Offline chigmuss
« Reply #4 on: April 08, 2013, 11:00:37 pm »
The guys above I'm sure have more experience of this but......you can get super glue remover from the likes of screwfix. Worth a try I guess, you never know you might get lucky, it's only about a fiver for a small tube.
