Author Topic: fitted mfsw today  (Read 735 times)
Offline marko
fitted mfsw today
« on: April 07, 2013, 10:09:12 pm »
fitted my new mfsw and steering controller module and airbag loom...
prob i have is steering light and traction light staying on!!
this fault is up
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 L
   Component: EPS_ZFLS Kl.070 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 356B1BEB5CAA80B0C2A
2 Faults Found:
02546 - Steering Limit Stop
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Mileage: 127770 km
                    Temperature: 13.0°C
                    Voltage: 14.00 V
                    Voltage: 13.80 V
00778 - Steering Angle Sensor (G85)
            000 -  -
             Freeze Frame:
tried the basic setting as in ross tech wiki but no luck
am i doing something wrong???
Offline xjay1337
  • -Receive: 377
Re: fitted mfsw today
« Reply #1 on: April 07, 2013, 10:14:40 pm »
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #2 on: April 07, 2013, 10:45:49 pm »
Hi Marko,
This happened to me also when i did mine.
Some useful advice from Eddie-NL, it took me a couple of goes before getting it sorted  :happy2:
Drive a short distance do the basic settings below (you may need to go into address 44)
switch the engine off
Turn wheel right, turn wheel left and turn back to the right
Basic Setting
Sensor for Steering Angle (G85)
Prerequisites:
Start the vehicle.
Turn the steering wheel one turn to the right and one turn to the left.
Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h.
 If the steering wheel is straight during the test drive then stop the vehicle with the wheels pointed straight.
 Ensure that the steering wheel is not moved again.
Keep the engine running and do not switch off the ignition.
System voltage at least 12.0 V.
[Select]
 [03 - Brake Electronics]
 [Measuring Blocks - 08]
 Group 004
 [Go!]
 Check field 1, the value has to be between -1.5 and +1.5 °.
 [Done, Go Back]
 [Coding-II - 11]
 OR (if Coding-II is not available)
 [Security Access - 16]
 Enter 40168, to enable the basic setting.
 [Do it!]
 [Basic Settings - 04]
 Group 060
 [Go!]
 After a successful basic setting, field 2 should say "OK".
 [Done, Go Back]
 [Close Controller, Go Back - 06]
Note: After successful basic setting, the Steering Limit Stop needs to be adapted too.
Offline marko
« Reply #3 on: April 07, 2013, 10:54:25 pm »
thanks guys...
all sorted..
didnt spend enough time at the limit stop.
 :laugh:
was freaking that the slip ring was the wrong version..
everything works perfect
 :happy2: :happy2:
Offline xjay1337
  • -Receive: 377
« Reply #4 on: April 07, 2013, 11:09:16 pm »
Glad you got it all sorted buddy.  :happy2: :happy2:
Offline omeydz
  • -Receive: 50
« Reply #5 on: April 08, 2013, 11:15:37 am »
Happy days! Pic to celebrate?  :grin:
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
