Author Topic: 3 wire maf sensor what r they ???  (Read 1965 times)
Offline rich golf gti mk5
« on: April 07, 2013, 11:00:05 pm »
I've currently own a gti 05 axx engine code and can't find any were witch wire is live n 2 feeders please if any 1 could check to see witch 1 is live I'd b very grateful. Code errors are running too rich/ lean and maf sensor. Iv changed maf and code said no live feed to maf plz plz help I'm stuck n don't no were to turn as my mechanic has no idea how to find the live when it's dead
Offline bigmig95
  • -Receive: 50
Re: 3 wire maf sensor what r they ???
« Reply #1 on: April 08, 2013, 09:29:19 am »
According to my diagrams for AXX you should have a white and yellow wire, green and yellow wire and a black wire.  The black wire should be the 12V feed.
My car on the other hand (AXX) has a yellow, brown and black wire  :confused:
Someone might want to confirm the feed is or isn't the black.
Hopefully this hasn't confused things even more. :smiley:
« Reply #2 on: April 08, 2013, 04:48:34 pm »
Thanks. After 2 week of hunting I've finally found out from vw them selves. Port number 1 ecu 2 earth 3 live thanks again
Offline DeWet
« Reply #3 on: June 03, 2018, 11:59:50 am »
Do you perhaps know to which pin on the ecu it connects?
Im installing bwa cylinder head in my NA 2.0 fsi and mine doenst have the maf sensor.
Bought the connector from vw but now need to wire it in somehow.
Sent from my SM-N920I using Tapatalk
