Author Topic: ko4 turbo help please  (Read 1580 times)
Offline DSG_Steel
« on: April 09, 2013, 05:46:22 pm »
Hi everyone
Iv just bought this ko4 kit off here
I want to get it fitted asap but just wondering if anyone here can tell me if iv got everything to fit it to my car or is there anything missing from this that I should get
Any advice will be appreciated
Thanks in advance
Billy
Offline martziniuk
Re: ko4 turbo help please
« Reply #1 on: April 09, 2013, 06:25:43 pm »
You'll need 4x seal kits for the injectors, turbo to cylinder head gasket, oil and water line crush washers. Are you running the S3 cooler and a CAI with K04 branch off?
« Last Edit: April 09, 2013, 06:27:21 pm by martziniuk »
Offline DSG_Steel
« Reply #2 on: April 09, 2013, 06:29:03 pm »
Thanks for the reply much appreciate  :happy2:
I will be running the forge twincooler
Billy
Offline martziniuk
« Reply #3 on: April 09, 2013, 08:59:16 pm »
If you wanted to run the OE engine cover you'd need an extra hose.
Offline DSG_Steel
« Reply #4 on: April 09, 2013, 10:23:16 pm »
Thanks mate
Im going to order all those gaskets and washers
Im got itg but I need to get that ko4 dv bung that merlin motor sport sell
Is there anything else I would need?
Billy
Offline Janner_Sy
  • -Receive: 113
« Reply #5 on: April 10, 2013, 10:25:49 am »
The DV connector will need extending to allow it to reach the front of the engine with the relocated DV
Offline DSG_Steel
« Reply #6 on: April 10, 2013, 11:53:41 am »
What kind of wire can I use to extend the dv wire?
Thanks billy
Offline martziniuk
« Reply #7 on: April 10, 2013, 06:03:08 pm »
Thanks billy
Apparently you can unpick the original wiring loom back to the new DV location, so an extension is not required.
I made up my own extension.
Offline GarethB
« Reply #8 on: April 10, 2013, 10:02:34 pm »
This is what Alex at AKS did when fitting my K04 - no extension necessary :happy2:
Offline Janner_Sy
  • -Receive: 113
« Reply #9 on: April 10, 2013, 11:10:55 pm »
Didnt know that.
Offline DSG_Steel
« Reply #10 on: April 11, 2013, 12:06:59 am »
Thanks for that guys  :happy2:
At least that one thing less to worry about
Offline james
« Reply #11 on: April 11, 2013, 04:09:36 am »
yea done it on mine,  just pull it back to the joint befor the coil packs.
Then get some of the plastic wire cover.   i did have the pn but cant find it.
Offline DSG_Steel
« Reply #12 on: April 11, 2013, 11:04:11 am »
What do I do with my old dv location?
« Reply #13 on: April 11, 2013, 11:31:09 am »
It is redundant. You already have the relocation pipe, you just need the relocation bracket that fits on the inlet manifold to refit the DV. :smiley:
Do you already have an upgrade HPFP?
Offline DSG_Steel
« Reply #14 on: April 11, 2013, 11:40:50 am »
Hi hurdy
Iv got the autotech hpfp
Do you know the part no. For the bracket or where can I get it from?
Billy
