Author Topic: Problem gti update ! Fixxxxxxed  (Read 11416 times)
Offline Dv21
« on: April 09, 2013, 11:02:36 pm »
Chaps not sure if this is in the right bit but I have a 05 plate gti I've done a ko4turbo s3 injectors pipewerks downpipe with de-cat milltek rest of the way forge front mount intercooler forge twin intake apr hpfp had the remap done at storm developments when the car boosts it fine when I brake heavy and come to a stop the car stalls has anyone had this before or know what it could be
Thanks Daniel
« Last Edit: May 19, 2013, 05:18:36 am by Dv21 »
Offline edd666999
  • -Receive: 89
Re: Problem gti
« Reply #1 on: April 09, 2013, 11:13:09 pm »
Dsg?
Offline Dv21
Re: Problem gti
« Reply #2 on: April 09, 2013, 11:14:48 pm »
Yes mate
Offline edd666999
  • -Receive: 89
Re: Problem gti
« Reply #3 on: April 09, 2013, 11:17:22 pm »
 :signLOL:
Welcome to my hell.
Have you had your car scanned via vcds for faults?
Does it happen in sport or normal mode or just manual?
Has your dog been mapped
Have you had any dsg work under warranty?
Offline Dv21
Re: Problem gti
« Reply #4 on: April 09, 2013, 11:21:24 pm »
Yeah I did fuel pump electrics malfunction cleared it down hasn't come back tho they are telling me my in tank pump is giving up and I need a s3 one or ttrs one other people are saying its not that I am lost do you have a problem like this ?
And dsg has been mapped
Offline edd666999
  • -Receive: 89
Re: Problem gti
« Reply #5 on: April 09, 2013, 11:24:38 pm »
Car was fine, dsg fine until apr k04 conversion.
When I'm booting it, coming to a stop stalls the car.
The issue I have is psi tuning left a multitude of errors in my ecu non of which I can link to this issue.
In tank pump sounds reasonable as when I'm doing 30mph and no boost/no real fuel demand it doesn't stall.
Offline edd666999
  • -Receive: 89
Re: Problem gti
« Reply #6 on: April 09, 2013, 11:26:00 pm »
If you find the solution could you let me know, I'll do the same for you.
Offline Dv21
Re: Problem gti
« Reply #7 on: April 09, 2013, 11:28:21 pm »
Yeah will do mate it proper confusing I'm dropping it Friday so they can look into it
Offline edd666999
  • -Receive: 89
Re: Problem gti
« Reply #8 on: April 09, 2013, 11:30:42 pm »
I assume your down south?
Do you know what part number for fuel pump? The ttrs rs3 in tank one
Offline Dv21
Re: Problem gti
« Reply #9 on: April 09, 2013, 11:33:22 pm »
Yeah I'm in reading Berkshire I have no clue mate tell me does yours drop the revs and sometimes pick up and other times stall ?? Almost like pinking
Offline edd666999
  • -Receive: 89
Re: Problem gti
« Reply #10 on: April 09, 2013, 11:44:10 pm »
Yeah it sometimes very close to stalling, I have done no more than 800miles since the conversion in August though. I was hoping resolving my uneven idle might stop it from stalling. My alternator is causing revs to drop and rise so getting that and my battery replaced next.
Offline Dv21
Re: Problem gti
« Reply #11 on: April 09, 2013, 11:47:58 pm »
I've probably done even less miles than you I've fitted a new battery I'm thinking it could be mapping never ever did it before conversion I'm really baffled
Offline edd666999
  • -Receive: 89
Re: Problem gti
« Reply #12 on: April 09, 2013, 11:54:01 pm »
Well I'm apr stage 3, loads of people have that map and couldn't find any reference to the issue elsewhere.
Yours is a more custom map.
Maybe related to the custom harness that's made? Incorrect readings sent to ecu?
Im going to swap to the "g" DV too.
Offline Dv21
Re: Problem gti
« Reply #13 on: April 09, 2013, 11:58:53 pm »
The DV been changed on mine made no differents totally lost
Offline edd666999
  • -Receive: 89
Re: Problem gti
« Reply #14 on: April 10, 2013, 12:00:59 am »
I was thinking dreaded dsg mech unit.
I tried a dsg reset which did nothing.
I hope it isn't lol that's a 2k job.
