Author Topic: Problem gti update ! Fixxxxxxed  (Read 11487 times)
Offline Dv21
Re: Problem gti
« Reply #15 on: April 10, 2013, 12:05:45 am »
Tell me about it can't be that
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
Re: Problem gti
« Reply #16 on: April 10, 2013, 09:43:34 am »
Seems odd but reassuring you both have the same problem, are you mapped by the same tuner?
Do you have low idles?  Perhaps this with the heavy decel are causing the stall... In VCDS you can raise the idle iirc.
You'd hope there would be some error code logged each time... Failing that can you run a real time VCDS scan.
Offline Dv21
Re: Problem gti
« Reply #17 on: April 10, 2013, 10:11:04 am »
No camfollower mine was mapped by storm developments custom map his is apr I think  :confused:
Offline Dv21
Re: Problem gti update !
« Reply #18 on: April 12, 2013, 06:10:43 pm »
Car was in garage today no further forward apart from new accelerator pedal being replaced and car only try's to stall when warm someone help me  :confused:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=p705n6bcpakcucsaf81cgt5032&/topic,19740.0.html
« Reply #19 on: April 12, 2013, 06:13:40 pm »
Has the DV been connected to the the intake correctly?
Offline Dv21
« Reply #20 on: April 12, 2013, 06:16:35 pm »
I would like to think so as was all fitted by a company called j-tech
Storm developments have re-mapped it and checked over the fitting and didn't find anything wrong with it
Offline Dv21
« Reply #21 on: April 12, 2013, 06:24:10 pm »
Richwig83 when you say correctly is there a wrong way ??
Thanks Daniel
Offline edd666999
  • -Receive: 89
« Reply #22 on: April 12, 2013, 06:25:41 pm »
I need to scan my car so you can see the menu of errors
Offline Dv21
« Reply #23 on: April 12, 2013, 06:26:52 pm »
Offline edd666999
  • -Receive: 89
« Reply #24 on: April 12, 2013, 06:29:48 pm »
I don't recall having any of yours though.
Offline Dv21
« Reply #25 on: April 12, 2013, 06:37:18 pm »
There they are edd666999
Offline james
« Reply #26 on: April 13, 2013, 08:28:55 am »
They are the same faults i had when my coil packs was fudged  :mad:
New packs and it all went away.
Try swapping with somone.
Offline Dv21
« Reply #27 on: April 13, 2013, 09:06:58 pm »
Really James thanks for that I will try that mate ill let everyone know soon as I've tried  :happy2:
Offline edd666999
  • -Receive: 89
« Reply #28 on: April 15, 2013, 05:04:39 pm »
These are what i had on my car this morning, i have had battery issues remember which could explain the last one.
000257 - Mass Air Flow Sensor (G70)
               P0101 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 102190 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 20:27:51
             Freeze Frame:
                    RPM: 5368 /min
                    Load: 100.0 %
                    Speed: 141.0 km/h
                    Temperature: 77.0°C
                    Temperature: 12.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.605 V
000406 - Engine Oil Temp. Sensor (G8)
               P0196 - 004 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 104739 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:00:40
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 6.0°C
                    Temperature: 7.0°C
                    Voltage: 11.049 V
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
I cleared these and went for a spirited drive, and the car cut out twice under hard braking in manual (doesn't seem to do it in sport or "d" and i don't use manual any more for this reason)
after the drive, no error codes at all. so its not flagging up an error when the car stalls. Possibly, fuel, ignition, air, voltage lol
Offline Dv21
« Reply #29 on: April 15, 2013, 08:48:13 pm »
Hmm we'll it's totally different codes to mine but mine stalls pretty much all the time now I'm really confused
