Author Topic: Problem gti update ! Fixxxxxxed  (Read 12038 times)
Re: Problem gti update !
« Reply #30 on: April 15, 2013, 10:00:15 pm »
Hmm we'll it's totally different codes to mine but mine stalls pretty much all the time now I'm really confused
I really can't help but have you tried doing a dsg basic setting as a troubleshooting procedure? If your clutch isn't releasing properly then this could help.
Offline edd666999
  • -Receive: 89
« Reply #31 on: April 15, 2013, 10:52:38 pm »
I tried this and I heard that the clutch should make noises during the reset but mine didn't
« Reply #32 on: April 15, 2013, 11:18:41 pm »
Hmm, mine was quite loud and clunky at times during the procedure.   :confused:
Offline edd666999
  • -Receive: 89
« Reply #33 on: April 15, 2013, 11:29:14 pm »
Maybe I did something wrong, what guide did you follow?
Offline Dv21
« Reply #34 on: April 16, 2013, 06:47:37 am »
Mine was reset too but didn't here any noise either
« Reply #35 on: April 16, 2013, 10:58:24 am »
I used Carl's guide and iirc the clunking only occurred when doing the Transmission Tolerances part.   http://www.mk5golfgti.co.uk/forum/index.php/topic,24158.0.html
« Last Edit: April 16, 2013, 11:08:25 am by bacillus »
Offline edd666999
  • -Receive: 89
« Reply #36 on: April 16, 2013, 12:43:54 pm »
Engine on or off?
« Reply #37 on: April 16, 2013, 01:06:19 pm »
Engine on or off?
Engine on as per prerequisites:
 Fluid Temperature 30...100 °C (86...210 °F), see Measuring Blocks, Group 019.
 Selector Lever in P
 Ignition ON
 Engine ON (Idling) for one minute or more
 Brake Pedal operated (hold for the whole procedure)
 Throttle Pedal not operated
Offline edd666999
  • -Receive: 89
« Reply #38 on: April 16, 2013, 03:15:57 pm »
ill give it another blast i think.
Offline Dv21
« Reply #39 on: April 16, 2013, 09:47:57 pm »
I took my car to the phirm today the guys down there are very helpful they spend about 45 mins with me driving testing things the car is booked in a week Saturday but they seem to think its air related fuel is fine so will keep you all updated
Thanks Daniel
Offline edd666999
  • -Receive: 89
« Reply #40 on: April 16, 2013, 10:52:01 pm »
Thanks Daniel
What DV version are you?  D or G?
What intake you running?
Offline Dv21
« Reply #41 on: April 16, 2013, 11:12:30 pm »
What's the differents d-g?? I've got a forge twin intake  :laugh:
Offline edd666999
  • -Receive: 89
« Reply #42 on: April 17, 2013, 12:22:39 am »
Can't believe you haven't read the million threads on which DV is best. Look at the part number on yours does it end in d or g.
It's right at the front of the engine bay on ko4 cars.
Offline Dv21
« Reply #43 on: April 17, 2013, 07:04:22 am »
Is it the thing with the piston in it ?
Saintsteve
« Reply #44 on: April 17, 2013, 07:54:52 am »
 :confused:
