Author Topic: Problem gti update ! Fixxxxxxed  (Read 11488 times)
Saintsteve
Re: Problem gti update !
« Reply #60 on: April 27, 2013, 09:52:19 pm »
what should they read?
What intake you running?? Oem or CAi?
Ideally readings as close to 0% but some intakes if non oem may have fuel trim adjust upto 15%!! Typically like Forge Twintake
Evoms and ITG read around 5-6%
Oem around 0-2%
ITG intake, gti running KO4
If yours reads when you check block 32, you don't need to log it, just read what it says as its an accumulative figure over time. It will give you 2 different figures. Idle figures are as near to zero, certainly under 10% would be acceptable.
If its in the Teens, I would be looking at what's been spoken over, as it means the Ecu is over correcting the fuelling, or trying to compensate a fault that lies elsewhere. :smiley:
« Last Edit: April 27, 2013, 09:54:27 pm by Saintsteve »
« Reply #61 on: April 27, 2013, 10:56:21 pm »
Ed try disconnecting the maf connector and see if your idle improves. With a bad maf it should.
Offline edd666999
  • -Receive: 89
« Reply #62 on: April 29, 2013, 12:26:03 pm »
Oem around 0-2%
lambda idle 0.1
lambda partial 7.4%
Offline edd666999
  • -Receive: 89
« Reply #63 on: April 29, 2013, 12:38:34 pm »
so misfires log upto 36 then reset, with no maf plugged in, no misfires.
can i drive the car with no maf to see if it still stalls when breaking?
« Reply #64 on: April 29, 2013, 05:10:25 pm »
Your fuel trim values are ok and yes you can drive the car without issue but you will probably get a CEL.   :smiley:
Offline Dv21
« Reply #65 on: May 19, 2013, 05:16:56 am »
Fixed  :laugh: :happy2: :grin: :P
« Reply #66 on: May 19, 2013, 06:28:11 am »
Oh come on?
You can't leave us all hanging like that.   :confused:
What was the problem? Are you 100% it's fixed?
Spill the Beanz  :popcornsoda:
Offline Dv21
Re: Problem gti update ! Fixxxxxxed
« Reply #67 on: May 19, 2013, 07:19:08 am »
Air mass along side forge twin intake it doesn't like dsg box cause it can't read the correct amount of air when changing down through the box tried standard all ok put back forge problem back  :happy2:
Saintsteve
« Reply #68 on: May 19, 2013, 09:36:53 am »
I don't think forges Twintake doesn't agree with mine either, my fuel trims won't go lower the 10% correction, and I feel its because of the Twintake.
No running problems though on the road though.
Great news on getting her fixed  :happy2:
« Reply #69 on: May 19, 2013, 09:44:23 am »
glad to the hear you got it all fixed
Offline Dv21
« Reply #70 on: May 19, 2013, 10:02:35 am »
Thanks gents and thanks to everyone that helped me along the way with advise  :happy2:
Offline edd666999
  • -Receive: 89
« Reply #71 on: May 19, 2013, 11:26:22 am »
So I have an itg intake, does this mean I have to get rid :(
Saintsteve
« Reply #72 on: May 19, 2013, 01:16:23 pm »
ITG isn't Twintake?  :confused:
Offline edd666999
  • -Receive: 89
« Reply #73 on: May 19, 2013, 01:40:25 pm »
Yeah but we have exactly the same issue, so i posted on the basis that removing his after market CAI resolved the issue, im aware the twintake and ITG intake are different though lol. :booty:
Offline edd666999
  • -Receive: 89
« Reply #74 on: May 20, 2013, 02:05:59 pm »
Disconnected the MAF and the issue disappears, in fact the car felt the smoothest it ever has!
Is that a fault MAF or CAI do you recon?
How much are MAF's? What the part number i need anyone know?
