Author Topic: Airbag cover  (Read 409 times)
Offline Johnny_tro
Airbag cover
« on: April 09, 2013, 11:26:41 pm »
Replacing this - is it simple enough? anyone done this?
Also how can I remove the airbag and avoid the airbag light coming up on the dash after? As I don't have vcds
« Last Edit: April 10, 2013, 07:25:59 am by Johnny_tro »
Offline PaulR32
Re: Airbag cover
« Reply #1 on: April 10, 2013, 10:57:10 am »
Disconnect the battery first. Then a flat head screw driver in the two holes on the back of the steering wheel twist and it pops off the airbag. Not sure on how to get the air bag off the cover tho.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Airbag cover
« Reply #2 on: April 10, 2013, 11:17:39 am »
To get the cover off is not an easy job
Take a picture before you do anything
Ground yourself before touching it
Remove the wiring loom
remove the 4x Nuts
lift the plate up
the cover has tabs that locate in the metal parts release them and pull on the cover
it will be tight, so may be a PITA
also it has some sharp edges
refitting is in reverse order
Cluster and Key coding
Location Great Yarmouth
