Author Topic: clutch pedal stuck to floor.........  (Read 11968 times)
Offline sandancer
« on: April 11, 2013, 07:33:49 pm »
My wife was out in the car, pressed the clutch and it stuck on the floor. I got her to pull it up with her foot then it never faltered for 2 miles home through the town centre. Any ideas, should i be concerned or is it a one off do you think ?
55 plate gti
Offline camfollower
  • -Receive: 31
  • Cam follower awareness.
Re: clutch pedal stuck to floor.........
« Reply #1 on: April 11, 2013, 07:35:44 pm »
New slave cylinder required probs.
Offline sandancer
« Reply #2 on: April 11, 2013, 07:37:27 pm »
Don't like the sound of that......
Offline Matto
  • -Receive: 116
« Reply #3 on: April 11, 2013, 07:46:41 pm »
Get your head in the footwell and see if the slave cylinder rod with the ball end on it and broken through the front of the pedal. My old mk4 did this. There is a spot weld that breaks on the pedal itself.
Like this:
You may find some similar broken bits to this in the footwell:
« Last Edit: April 11, 2013, 07:53:54 pm by Matto »
Offline sandancer
« Reply #4 on: April 11, 2013, 08:06:47 pm »
I'll check that tomorrow, i knew it was a mk4 problem, so fingers crossed.......
Offline vRSAlex
  • -Receive: 253
« Reply #5 on: April 11, 2013, 08:49:41 pm »
Only on mk4's that fault.  Mk5 is a different setup.
Have a look under the car and see if there are any drips of fluid around the bottom of the gearbox.
Follow AKS tuning on Facebook
Offline sandancer
« Reply #6 on: April 11, 2013, 09:14:06 pm »
Will check in the morning, thanks.
Offline xjay1337
  • -Receive: 377
« Reply #7 on: April 12, 2013, 12:05:26 am »
As said the clutch pedal mount is a Mk4 problem, not a Mk5.
Going to likely air in the system, I would suggest as above - inspecting the hydraulic circuit, if no leaks are found I would suggest bleeding through new fluid and ensuring there is no air in the system.
It could be there was a small bubble which at that specific time caused a problem.
Hear it happening loads when mates change out slave cylinders, bleed it through, works all good, drive down the road and end up with clutch pedal on the floor, a quick re-bleed sorts it.
Offline JamesG
« Reply #8 on: April 12, 2013, 03:14:10 am »
Happened to me just after i got mine,turned out to be the master cylinder at the back of the pedal. Luckily was still under warranty.
Pirelli Edition:- APR stage 2+ map,Revo/BSH intake,Autotech hpfp internals,3" downpipe & de-cat,Sachs uprated clutch with smf conversion,H&R springs,race spec superpro polly bushes. 348bhp 360lbft.
Offline sandancer
« Reply #9 on: April 12, 2013, 07:32:00 am »
Did you have any fluid in the footwell when the master cylinder went ?
Offline sandancer
« Reply #10 on: April 12, 2013, 07:29:50 pm »
Noticed clutch fluid on the bell housing under the car, looks like its the slave cylinder then !
Offline phoenix
« Reply #11 on: April 12, 2013, 10:59:20 pm »
camfollower was right then... sorry to hear this mate :sad1:  whats the damage on getting this done?
Offline xjay1337
  • -Receive: 377
« Reply #12 on: April 12, 2013, 11:09:37 pm »
It's like £40 for a genuine one and 30 minutes to fit and bleed it if everything goes right.
Offline sandancer
« Reply #13 on: April 13, 2013, 10:38:52 am »
I though it was a 'box out job ?
It's under warranty (luckily!) so fingers crossed it's all ok.
If the 'box comes out I'll get them to check the clutch plate as well.
Offline xjay1337
  • -Receive: 377
« Reply #14 on: April 13, 2013, 11:45:06 am »
Well, I should have said, on the 5 speed cars (IE Mine) its £40 and half an hour. I do not know if it's more on a 6 speed.
