Author Topic: Help needed. Vcds  (Read 889 times)
Offline gazon69
Help needed. Vcds
« on: April 12, 2013, 10:08:34 pm »
Took out my clocks today, replaced them and now i have the traction light on and tyre pressure monitor. Can anyone advise what i need to go into in vcds please.
Offline skard
  • -Receive: 245
Re: Help needed. Vcds
« Reply #1 on: April 12, 2013, 10:10:18 pm »
Ignition on, full lock one way, hold it, full lock other way, hold it, straighten up wheels and drive slowly for about 50ft. Lights should go off
Offline gazon69
« Reply #2 on: April 12, 2013, 10:21:13 pm »
done the lock one way then the other. Power steering then te activated, took it out for a drive and still have those two lights on
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: April 12, 2013, 10:28:06 pm »
when you say you took your clocks out, did you change them to a different one or did you put the original ones back?
Cluster and Key coding
Location Great Yarmouth
Offline gazon69
« Reply #4 on: April 12, 2013, 10:32:15 pm »
yes. Changed to another then replaced originals.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: April 12, 2013, 10:34:07 pm »
did you get immobiliser active on the computer?
Offline gazon69
« Reply #6 on: April 12, 2013, 10:40:45 pm »
you got p.m mate
