Author Topic: How much boost does an ED30 Run?  (Read 3163 times)
Offline cossy
  • -Given: 17
  • 57 REG ED30 5325 MILES!
« on: July 29, 2009, 11:06:01 am »
Just had a couple of reduced boost maps from superchips.
Each map reduced by 0.05 bar.
How much BHP would I roughly be getting with reducing the boost by this much?
SC unable to tell me. :P
Re: How much boost does an ED30 Run?
« Reply #1 on: July 29, 2009, 11:14:30 am »
I wouldn't have thought that reducing the boost by 0.05bar / 0.73psi would make too much difference.
Offline cossy
  • -Given: 17
« Reply #2 on: July 29, 2009, 11:21:59 am »
thats what i thought, but didnt think they meant 0.5bar.
What should it be running standard?
cheers
« Reply #3 on: July 29, 2009, 11:34:32 am »
0.5bar would be 7.3psi which would make it almost stock and not worth the money!!
I'm running peak 23psi on stage 2+. Stage 1 remap would be around peak 21psi and stock is (from memory) around 13-14psi, so knocking off 0.5bar is basically a stock map, which would be really strange!!
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #4 on: July 29, 2009, 10:58:19 pm »
mines stage 1 APR and peaks 21 psi , dropping to 17 across range .....
sure they didnt mean 0.5 psi increments ???
is this to get round an issue?
if so it may be very small drops to get around triggering the failsafes...
Red ED35 5dr DSG
BLOG | BUILD
Offline SteveS
« Reply #5 on: August 05, 2009, 01:31:21 pm »
im revo stage1 and at about 23peek psi, 20-21psi general
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #6 on: August 05, 2009, 02:03:57 pm »
my KO3 runs 22psi and drops to about 15psi.  :smiley:
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #7 on: August 05, 2009, 09:54:57 pm »
Presumably you guys have a turbo boost gauge fitted in your cars where you are getting the readings from.
Any recommendations for which gauge I should consider/avoid?
« Reply #8 on: August 05, 2009, 11:13:40 pm »
You can also get this info via VCDS.   :smiley:
