Author Topic: Jacking points  (Read 1424 times)
Offline coolhandluke
  • -Given: 28
Jacking points
« on: April 13, 2013, 06:28:29 pm »
Getting myself a trolley jack and wondering where's the best place to locate it when jacking up to remove a wheel back or front.
Is it ok to use the area on the sill where the VW supplied jack would go?
Where would you place an axle stand once you have the car of the ground?
Offline ripmateyy
Re: Jacking points
« Reply #1 on: April 13, 2013, 08:03:24 pm »
I used the back of the wish bone mount for the axle stand
Offline skard
  • -Receive: 245
Re: Jacking points
« Reply #2 on: April 13, 2013, 08:05:39 pm »
My mate has a two post lift and I'm always using the strengthened bit of sill to lift it (denoted by arrows).
As for where to put axlestands, it depends what you're doing. If changing brakes then on the wishbone bush as suggested is good.
