Author Topic: Koni FSD and Ebach springs  (Read 12361 times)
Offline xxx_mojo_xxx
  • MUBster DUBster
Re: Koni FSD and Ebach springs
« Reply #30 on: September 06, 2009, 07:30:09 pm »
Interesting you say that, I have a set of ARBs waiting to be installed.  So, you're recommendation is to go for the Koni FSDs...
How do I know I'm getting the later revision, and also... I don't want my car to sit any higher than what it is already - having it dropped with the sportlines.
« Reply #31 on: September 06, 2009, 07:48:09 pm »
....I can't tell you what you should go for but can only say that if you want a good compromise between stock and coilover types of suspension, then the Koni FSD's are a good solution.
If you are buying new, then of course they'll be the later version unless they've been on someone's stock shelves for years.
Give Awesome a call - They'll help.
Offline candy turbo
« Reply #32 on: September 06, 2009, 08:04:24 pm »
if you want eibach springs why not use there matched dampers ? they must be the best match ! thats what i ll be fitting if i ever need new dampers (which i doubt 7.5 k miles )
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #33 on: September 06, 2009, 08:06:53 pm »
^^^ x 2
Also your going to have to change to eibach pro springs which have a <20mm drop compared to the sportlines which have a 40mm drop  :confused:
  • MUBster DUBster
« Reply #34 on: September 07, 2009, 07:55:34 am »
Can't I use my current sporrtlines with eibach dampers, then?
Offline SteveP
  • -Given: 117
  • -Receive: 341
    • My Project
« Reply #35 on: September 07, 2009, 08:02:51 am »
yes you probably can, it's the FSD's with sportlines that are recomended that I was refering to  :smiley:
« Reply #36 on: September 07, 2009, 08:41:59 am »
....Mo, it's as Steve says - The Koni FSD's will only work as they are designed to if combined with particular springs (Eibach Pro springs being one of them). Those particular springs won't lower your car as much as you may want to, so it's a choice between the ride that the FSD's provide and the stance you want. The FSD setup will lower you a small amount from standard but not a lot. At least the FSD's don't mean you have to be jacked up like a stock American Golf!
Have you driven a GTI with Koni FSD's to check if you like them or not?
  • MUBster DUBster
« Reply #37 on: September 07, 2009, 09:02:30 am »
Now that's an offer that I can't refuse... that way I get to see how the car looks and also compare how it behaves in relation to my setup... any kind offers?
« Reply #38 on: September 07, 2009, 09:17:39 am »
....That is the best and most ideal way to find out if you like something. I was lucky with my FSD choice because a good friend had it on his GTI and we chose a route with both rough and smooth roads and drove each other's cars back-to-back. More recently I also 'test-drove' KW-V3's before deciding.
If my car still had KoniFSD's I'd be happy to arrange to meet up with you. Perhaps start a new thread titled "Help - Has anyone got Koni FSD's?" - Relying on someone dropping by on this thread and reading this far may not achieve it.
:smiley:
Offline Cochese
« Reply #39 on: September 07, 2009, 09:55:59 am »
 I've got FSd's, Eibach springs and Eibach ARB's. You're welcome to have a shot of my car mojo, only problem is I live in glasgow which I presume is many miles away from you.
Pieces of eight!
  • MUBster DUBster
« Reply #40 on: September 07, 2009, 10:29:47 am »
You're a gentlemen, thanks!  It's a bit far to travel from down south in Luton.
Appreciate the kind offer and gesture.  :happy2:
Offline Cochese
« Reply #41 on: September 07, 2009, 01:57:55 pm »
^^ no worries dude. :happy2: i knew you'd be far away, just not that far  :signLOL:
Pieces of eight!
