Author Topic: Cost of resetting airbag warning light  (Read 1416 times)
Offline andyR43
« on: April 14, 2013, 09:43:04 pm »
Fitted some Recaro seats to the front of the Golf and, as they don't have airbags, my airbag fault light is now on. I'm going to pop down to the main dealers to get the lights reset and was wondering what sort of price they would probably hit me with. Anyone got any ideas as to what I should be paying? :scared:
Keeping it original..............or not!!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: Cost of resetting airbag warning light
« Reply #1 on: April 14, 2013, 09:45:40 pm »
do the recaros have airbags?
Cluster and Key coding
Location Great Yarmouth
Offline andyR43
« Reply #2 on: April 14, 2013, 09:53:03 pm »
No they don't mate.
« Reply #3 on: April 14, 2013, 10:00:21 pm »
You need to either get them coded out or Recaro do a special plug to bypass your lack of airbags.
Offline Rhys_Gti
« Reply #4 on: April 14, 2013, 10:02:25 pm »
My local was around £40 I think
Offline stu_no_1
« Reply #5 on: April 14, 2013, 10:12:11 pm »
dont you have to use a resistor to stop the air bag light coming on
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
« Reply #6 on: April 14, 2013, 10:49:06 pm »
This. I made the resistors up and was pretty easy
Offline andyR43
« Reply #7 on: April 15, 2013, 01:16:18 pm »
Okay update time. I went to the VW main dealers in Yeovil and, like Amy Winehouse, they said no, no, no! They also said if it could be done then they wouldn't due to insurance reasons.
Went to a diagnostics place and they said they can't be coded out.
Went to Autotechnics in Gillingham, Dorset and they spoke to the man from Bosch I believe. He said the original coding cant be changed as the airbag coding is  one time only. He also said off the record that the only way to get over it would be to fit 2.5-3 Ohm resistors into the airbag circuit to fool the car into thinking that the airbags were still there.
Looks like that is the only way forward so if anybody can explain how I go about this then your help would be much appreciated.  :happy2: I'm assuming I would have to connect the resistors to the yellow airbag connectors under the seats but which wires do i connect to as there are 3? :confused:
Offline RSam84
« Reply #8 on: April 15, 2013, 03:00:10 pm »
Offline andyR43
« Reply #9 on: April 15, 2013, 03:51:15 pm »
Cheers for that Sam  :happy2: Do you know which wires I connect the resistor to as there are 3 wires going to the connector, Green, White and Brown.
Offline andyR43
« Reply #10 on: April 15, 2013, 09:49:24 pm »
Cheers for all the replies guys and a massive thank you to JoeDarka and RSam84. I know where I'm going with it all now.  :notworthy:
