I bought a 300mm long T8 torx screw driver off ebay, then its easy to do with everything in situ, just have to prise the cover off gently, tilt the glass out so there is enough access to the 2 screws that need removing, unplug power socket and replace with new unit. Take it slowly, worth a go, if you get stuck, then take to £90 a side dealer.
