Author Topic: How would these fit - 19 x 8.5 ET45  (Read 888 times)
Offline Johnny_tro
« on: April 15, 2013, 10:43:39 pm »
Look, fit and practicallity etc? just on or inside the arch etc.
Re: How would these fit - 19 x 8.5 ET45
« Reply #1 on: April 15, 2013, 11:08:32 pm »
perfectly flush with the arch.  :happy2:
Offline Johnny_tro
« Reply #2 on: April 15, 2013, 11:19:48 pm »
Thank you kindly - so with the wrong drop/tyre these will clearly start to rub/scrape?
« Reply #3 on: April 15, 2013, 11:29:14 pm »
Yes!, you cant go to low!. 8.0j 45 ET is perfect for the MKv.  :happy2:
Offline ConorF
« Reply #4 on: April 16, 2013, 10:18:03 am »
My NUE's are 19.8.5 ET45, I have no rubbing issues as yet, arch sits just above the tyre front and back!
When my 20mm spacers are on the rear, then i rub ;)
Offline Johnny_tro
« Reply #5 on: April 16, 2013, 10:25:03 pm »
Excuse what may be a silly question.....but can you use 8.5 or 9.0 and just have the camber adjusted so the tops angle in?
Simple solution as below......or is this just simpy for a show look/style?
« Last Edit: April 17, 2013, 09:24:01 pm by Johnny_tro »
Offline Johnny_tro
« Reply #6 on: April 17, 2013, 09:24:32 pm »
Offline Aweful_Truth
« Reply #7 on: April 18, 2013, 02:05:30 am »
im running that exact fitment on my GTI at the moment with the wheels im not selling if your interested  :evilgrin:
theyre totally flush with the arches, if your not lowered they dont rub, when i was on springs they rub very occasionally, like hard cornering on an uneven road... and now im on coilovers and whacked it right down for a show and it scrubs everywhere haha but its silly low... im raising it up tomorrow for normal driving again
overall, they work fine  :happy2:
To Bad, So Sad, Bye Bye!
Offline DRM92
« Reply #8 on: April 18, 2013, 10:39:21 pm »
Should fit fine, I ran the same apart from ET 35 on my BLQ's. However upfront I needed to do the screw mod to stop it rubbing, however you will probably wont come across this problem! (Was on JOM coilovers all the way down.)
« Reply #9 on: April 19, 2013, 10:45:44 pm »
DRM92, what's this screw mod you speak of.... Presume it's more than just removing the screw ??
