Author Topic: NEED HELP!!! PLEASE!! No Power Steering  (Read 6855 times)
Offline russb94
« on: April 17, 2013, 10:05:06 am »
Hi guys!
I am new to this forum so go easy  :happy2:
I have a Mk5 golf gti which i left to stand for around 3 months. When i came to start it the battery was dead so i jump started it. I was driving along there   was a few lights on. The steering light,  ABS, ESP and the tyre pressure light. i looked on forums and it said to do the left to right thing, when i did that i then it went to partial power steering grrr!!
I've since put it on bosch kts 670 diagnostics and it comes up with:-
steering angle sensor  fault (which wont clear)
steering end stop - basic settings not peformed/wrong (which wont clear)
and both rear wheel speed sensors (which will clear but come back)
any ideas? its driving me crazy!
« Last Edit: April 17, 2013, 10:18:38 am by russb94 »
Offline Matto
  • -Receive: 116
Re: NEED HELP!!! PLEASE!! No Power Steering
« Reply #1 on: April 17, 2013, 12:23:35 pm »
Sounds like you need to perform the basic settings.
Have a look here and scroll down to basic settings. [http://wiki.ross-tech.com/wiki/index.php/VW_Golf_(1K)_Steering_Assist
A tip for doing the end stop setting, hold it on the stop lo her than stated. 20-30 is what worked for me.
Offline russb94
« Reply #2 on: April 19, 2013, 11:06:26 pm »
I've tried this today and it didn't clear. Im not 100% sure on the
"If the 02546 - Steering Limit Stop 005 - No or Incorrect Basic Setting / Adaptation fault will not clear after driving the vehicle and completing the VW Golf (1K) Steering Assist procedure, increase the time in-between key cycles to 30 seconds or more."
what am I meant to do for 30 seconds?
Thanks Russ
« Last Edit: April 20, 2013, 04:40:36 pm by russb94 »
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: April 20, 2013, 10:38:57 am »
try doing the basic settings
switch the engine off
start the engine > turn all the way to the left and hold > turn all the way to the right and hold > turn all the way to the left
Cluster and Key coding
Location Great Yarmouth
Offline russb94
« Reply #4 on: April 20, 2013, 04:42:38 pm »
i tried this but it didnt work :( i cant see what im doing wrong.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: April 20, 2013, 05:33:52 pm »
are you using vcds for this?
where are you located?
Offline russb94
« Reply #6 on: April 20, 2013, 05:42:36 pm »
Yeah i am using vcds and its a proper one. When i click on/off/next it comes up with error and not availible to do the adjustments
im from malvern in worcestershire (about 40 miles south of birmingham)
Offline biffobear
« Reply #7 on: April 20, 2013, 07:53:17 pm »
I think you will have to fix the wheel speed sensors before it will allow you to carry out basic settings.
