Author Topic: Damp DV but is it dodgy?  (Read 797 times)
Offline daisydave
« on: April 17, 2013, 06:31:22 pm »
Hi all, don't post much on here as I'm more of a aircooled boy with a bay but have had my gti for about a year now and tbh I have grown quite attached :) Recently I have been hearing a faint hissing when the boost comes in and a blow off noise when I lift off the throttle almost like a dump valve :/   I also seem to be down on top end power like I'm down on boost.
I have done some research and been under her today and have found some oil collecting around the intercooler inlet so have cleaned the seal up and ordered a set of new seals to replace then all.
I also took a look at the DV valve as I was pretty sure this was the culprit and found the connector swimming in oil, if there is oil passing it surely so will air??  so I have ordered a new valve.
Just wondered if you lot thought this sounds about right or if there is other things I could be checking for?
Also the car is an 05 dsg and is totally standard.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Damp DV but is it dodgy?
« Reply #1 on: April 17, 2013, 06:39:00 pm »
If you have oil on it there's a very high chance the diaphragm has split and spitting out air & oil  :sad1:
At least it's a cheap fix  :happy2:
Intercooler pipes always end up leaking, your best off buying the small pipe connector
Graeme
Offline daisydave
« Reply #2 on: April 17, 2013, 06:48:38 pm »
Coolio cheers but small pipe connector? Do you mean the seals on the actual boost pipe, if so that's what I have ordered :)
Offline GTI5
« Reply #3 on: April 17, 2013, 06:51:16 pm »
Oil on the DV is possibly a sign of your breather system letting by. The early PCV valve systems were prone to failure and there has since been a few revisions.
Did you have any splits or tears in the DV rubber diaphragm?
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline daisydave
« Reply #4 on: April 17, 2013, 06:57:57 pm »
I never took it off as I was running out of time and as there so cheap I thought I would change it as a matter of course being that they do appear to be a bit of a week link.
I have checked the PCV system by undoing the oil filler cap whist running and the revs dropped as they should or is there other things I should be looking for?
Offline GTI5
« Reply #5 on: April 17, 2013, 07:11:09 pm »
I never look it off as I was running out of time and as there so cheap I thought I would change it as a matter of course being that they do appear to be a bit of a week link.
I would physically remove the Front PCV and inspect the valves.
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline daisydave
« Reply #6 on: April 17, 2013, 07:22:04 pm »
Ah ok, what I'm I looking for just worn split seals and diaphragms?
Offline GTI5
« Reply #7 on: April 17, 2013, 07:33:03 pm »
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #8 on: April 17, 2013, 07:58:14 pm »
IIRC it's the pipe from the discharge pipe to the intercooler that leaks, it's only a small section of pipe (20cm ish)
Offline daisydave
« Reply #9 on: April 19, 2013, 04:24:29 pm »
Well replace my DV today aswell as some boost pipe seals, this is what the valve was like so please a looked Ito this!
I'm surprised at the difference, it's not just better than before I noticed the noise it's better than ever. A lot better throttle response and the car takes off now it's like having a new car :)
