Author Topic: Fitting boost gauge  (Read 23219 times)
Offline iainalpine
Fitting boost gauge
« on: July 30, 2009, 02:05:22 pm »
Ok guys, a quick question and request of some of your wisdom. What is the best route for running a vacuum hose(for boost gauge) into the cabin of the mk5. Im going to be fitting the new south gauge next week which will be just in time for putting the Forge FMIC on.
cheers
Iain
2006 MKV GTI, DSG, Stg2 Revo map, VWR front splitter, KWv3's, Eibach rollbars, Walk kit, Carbonio induction kit, Full Milltek exhaust system, Forge FMIC
Re: Fitting boost gauge
« Reply #1 on: July 30, 2009, 03:03:43 pm »
John_o is your man Iain as he has fitted a boost gauge himself!  :happy2:
« Last Edit: July 30, 2009, 03:08:32 pm by Greenouse »
Offline iainalpine
« Reply #2 on: July 30, 2009, 03:09:43 pm »
Thankyou Mr Greenhouse
Iain
Offline NEWEY
    • Flickr
« Reply #3 on: July 30, 2009, 03:17:14 pm »
here is the link to a guide on how to fit it :)
http://www.mk5golfgti.co.uk/forum/index.php?topic=2073.0
TSR big turbo mk5 golf gti
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #4 on: July 30, 2009, 03:25:27 pm »
Ian , I have replied via PM  :happy2:
where do you plan to take the feed from?
its a bit different for you , as you need to route a boost pipe , whereas for the DEFI I had to route an electrical wire.
same principal though.
depending on where you take the feed from , it can go through bulkhead either near battery or above pedals.
I chose the former.
also do a search on golfmkv.com , as many US guys have fitted the new south gauge.
have a read and see what you think
Red ED35 5dr DSG
BLOG | BUILD
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #5 on: July 30, 2009, 03:47:00 pm »
i fed mine down the front wheel arch and in through a hole near the fuse box.  :smiley:
also if you look on the other side there is a hole in the firewall with a bung in it that comes out.  :smiley:
Offline iainalpine
« Reply #6 on: July 30, 2009, 05:31:23 pm »
Cheers for all the info there guys.
Joe, some good areas to go and look at there. Cant believe your getting rid of the car. R32 is lovely but you defo feel it throwing it into the bends. would say not as chuckable as the gti. good luck with whatever you end up doing.
Iain
Offline neg
  • gone old skool
« Reply #7 on: July 31, 2009, 12:12:42 am »
Some more info here
Offline cmdrfire
    • Commander Fire - my blog
« Reply #8 on: July 31, 2009, 12:21:01 am »
There's a rubber plug behind the 12V battery. You can cut off one of the "nipples" on the plug and feed the wire through from there. It will arrive in the passenger side of the vehicle; take off the foam cover from under the dash, and you will see where the wire comes through. From there you can feed it across to the driver's side. It is very neat and the integrity of the firewall is not compromised.
I also recommend use of the DEFI gauge as it passes an electrical signal through instead of allowing boost vacuum routed through into the passenger cabin.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #9 on: July 31, 2009, 08:08:12 am »
nice link neg , Ive added it to my product review if thats OK  :happy2:
bring a tear to your eye ?
vacuum line gauge  = route driver side
electrical line gauge = either side routing
Red ED35 5dr DSG
BLOG | BUILD
Offline neg
  • gone old skool
« Reply #10 on: July 31, 2009, 08:35:22 am »
No problem at all, saved me moving it  :wink:
It does actually, I was thinking only yesterday how I miss the paddles and DSG exhaust note change  :sad1:
I'll be bringing some of the mk5GTI back out later - the Monza's are going on the Wife's Touran  :laugh:
Offline iainalpine
« Reply #11 on: July 31, 2009, 09:06:03 am »
Thanks for all this. another quick question, where are you tapping into for the vacuum line. I used to always go for the Fuel Pressure Regulator, is that the best option here?
Iain
Offline joesgti
« Reply #12 on: July 31, 2009, 09:35:40 am »
Iain
always wanted a mk4 R32 and cant see myself ever haveing the chance to own one in the future so i thought fcuk it! i know its no where near the mk5 gti, but if i dont like it, il be able to sell it for as much as i paid for it.  :smiley:
Offline cmdrfire
« Reply #13 on: July 31, 2009, 12:06:34 pm »
Iain
Forge and BSH both make a multitap thingy that will go into the vacuum line and provide you with a tap point.
Offline iainalpine
« Reply #14 on: July 31, 2009, 02:14:06 pm »
where do you fit the multi tap thing for the boost gauge? do you really need to use this as i think the gauge (new south) is supplied with a "T" peace for this very function.
Iain
