Author Topic: Fitting boost gauge  (Read 23266 times)
Offline cmdrfire
    • Commander Fire - my blog
Re: Fitting boost gauge
« Reply #15 on: July 31, 2009, 03:24:20 pm »
http://www.bshspeedshop.com/instructions/boost_tap.pdf
Forge one goes in the same location.
And t-piece fitting is fail, not nearly street or shiny enough.
Really.
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #16 on: July 31, 2009, 03:30:50 pm »
and prone to causing leaks!
a kit of some form another is well worth it  :happy2: (I used forge one..)
you can also take a signal from an aftermarket forge DV if you have one fitted...
Red ED35 5dr DSG
BLOG | BUILD
Offline iainalpine
« Reply #17 on: July 31, 2009, 03:38:11 pm »
Wicked guys, thnaks for this. Have ordered the new forge one that pretty much clips into place.
The one thing i can say about this forum is that, when you need help you get it.
thank you for this
Iain
2006 MKV GTI, DSG, Stg2 Revo map, VWR front splitter, KWv3's, Eibach rollbars, Walk kit, Carbonio induction kit, Full Milltek exhaust system, Forge FMIC
Offline cmdrfire
« Reply #18 on: July 31, 2009, 03:49:48 pm »
<3 forge
You may as well have gotten the full forge dv as John_O suggests.
Forge+BSH ftw.
Offline jt1
« Reply #19 on: August 02, 2009, 03:22:19 pm »
Some more info here
Cheers neg for a great write up :congrats:
Followed this guide to fit mine today, really good write up, made it tons easier :happy2: only thing is i now reckon i,ve got a major boost leak :confused: as it's spiking at just 11psi (gutted) :sad1:
Offline cmdrfire
« Reply #20 on: August 02, 2009, 06:09:43 pm »
Sure the boost leak isn't occurring because of faulty installation?
Offline jt1
« Reply #21 on: August 02, 2009, 06:15:16 pm »
Yes, double checked everything to make sure, had a feeling it was'nt running right but were'nt to sure, thought it was just me :rolleye:
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Over the top mod list ;o)
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #23 on: August 02, 2009, 10:18:54 pm »
^^^ Agreed, if it wasn't for the fact it doesn't work with OEM bluetooth installed I would have brought this a long time ago  :sad1:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #24 on: August 02, 2009, 10:52:52 pm »
kufatec is really slick but a moving needle conveys far more 'dynamic' info  :happy2:
Red ED35 5dr DSG
BLOG | BUILD
Offline cmdrfire
« Reply #25 on: August 02, 2009, 11:00:30 pm »
What's the sampling rate like on the Kufatec stuff? I keep meaning to buy their Bluetooth thing. I imagine it's just picking data up from the CAN right?
Offline joesgti
  • Eat my sick, Eat my sick.
« Reply #26 on: August 03, 2009, 10:37:39 am »
Some more info here
somethings defo not right there, mine peaks at 22psi!!  :confused:
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #27 on: August 03, 2009, 11:22:23 am »
indeed at that level you are running std boost levels as joe states
Id guess you may have defaulted back to stock if the batteries been disconnected etc
Red ED35 5dr DSG
BLOG | BUILD
Offline jt1
« Reply #28 on: August 03, 2009, 02:11:49 pm »
Thats what i thought but the battery has never been dissconnected, got it booked in at a place near me who reckons he can do a pressure test on it to see if there are any leaks, if there are no leaks then i'll get in touch with custom code to see if they can check the map, so fingers crossed it should be sorted soon.
Offline joesgti
« Reply #29 on: August 03, 2009, 02:23:44 pm »
just check the dv, 99% of the time, its the dv.  :happy2:
