Author Topic: Tiny knock on clutch Change  (Read 905 times)
Offline Mertyvw
« on: April 18, 2013, 08:27:07 pm »
Hi guys I've just noticed today that once changing into gears one and two I get this little knock in to the change it only does it in gears 1 and two the rest are fine and also when I drop down from gears it all ok .
Anyone have any ideas of what it could be?
Black 5 Door TDI with BBS Pescaras, R32 Spoiler, Tints All Round. RCD510,CAN 7NO I aint touching the Engine> Im frightened of power :D
My sig pic is still to big.
Offline Mertyvw
Re: Tiny knock on clutch Change
« Reply #1 on: April 19, 2013, 08:55:56 am »
Bump
Offline Mertyvw
« Reply #2 on: April 20, 2013, 06:53:46 pm »
Bump
Offline doylebros
« Reply #3 on: April 20, 2013, 09:24:57 pm »
Read the intro section on this link
http://www.myturbodiesel.com/1000q/a5/clutch-DMF-replacement-Volkswagen.htm
Common is clutch/flywheel for strange noises!
However, get it on a ramp and see is there's any thing simple first  - as the clutch fault is expensive!
Offline Mertyvw
« Reply #4 on: April 20, 2013, 09:34:43 pm »
Thank you i have actually had the flywheel, the clutch changed andthe gearbox reconditioned last summer. Hopefully it nothing big ill have a read
