Author Topic: Washer bottle power loss  (Read 706 times)
Offline rich golf gti mk5
« on: April 19, 2013, 09:26:15 am »
After tweaking bits n bobs with vagcom my washer bottle seems to of lost its umph still works but not as powerful any ideas plz
Offline cleanme
Re: Washer bottle power loss
« Reply #1 on: April 19, 2013, 09:42:19 am »
What's the battery juice like?
Offline john87
  • -Receive: 53
« Reply #2 on: April 19, 2013, 09:48:14 am »
My washer bottle's always had a slight delay before it starts spraying.. when you pull the stalk, you hear the pump start when around a second later the jets start working.
Is there a filter on the pump inlet?
« Reply #3 on: April 19, 2013, 02:03:11 pm »
Don't no about battery havnt checked but it was fine until I played about with vag com. Just seems less powerful. And I also don't no about a filter. I put a setting on vag com and washer bottle light was always on as if it was empty but I sorted that.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: April 19, 2013, 02:20:23 pm »
No sensor fitted
Cluster and Key coding
Location Great Yarmouth
« Reply #5 on: April 19, 2013, 02:57:27 pm »
Like I said above only lost power wen I played with vag com d u think I may of turned sensor off ?
Offline GTI-Pirelli
  • -Receive: 27
« Reply #6 on: April 19, 2013, 03:20:59 pm »
Before you started to tinker with the settings did you save a scan???
If you did, then the coding for each of the modules will be saved on the output. If it is something you have recoded you will be able to put the coding back to how it was originally then start from scratch.
e.g.
   Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000008875632
   Coding: E58D8F2700041500471400001400000000097F075C00010C000000000000
   Shop #: WSC 01357 011 00200
   VCID: 336F1FCB521B6980EC7
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 180908 021  0501
   Coding: 00038805
   Shop #: WSC 01357
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     091008 054  0402
   Coding: 00471213
   Shop #: WSC 01357
Good luck.
2017 Audi S4
« Reply #7 on: April 19, 2013, 05:53:23 pm »
Didn't save it. Newbie mistake doh
