Author Topic: Team Dynamic wheels questions...help!!  (Read 3260 times)
Offline nick-barnes07
Re: Team Dynamic wheels questions...help!!
« Reply #15 on: July 31, 2009, 05:18:41 pm »
yes he did, they will fit them at the place you are collecting from if need be, they may also track them up for you for cheap as well if they aint to busy!!!!! they got a good tracking machine that is done digitally ..
Offline WhiteGTI
  • F-A-S-T
« Reply #16 on: July 31, 2009, 06:30:24 pm »
Ben - cheers dude! Yep they are exact to your ones!
Nick - yeah I was contemplating getting it done there, I'll check out the place tomorrow. See you in the morning mate.
2006 E46 BMW M3 - 343hp
« Reply #17 on: July 31, 2009, 06:53:33 pm »
i had a word with them and they will do it all for you for £20-£30 , thats a 4 wheel alignment, fit and balance all tyres to car as well!!!!!!!
Offline gazbutS3
« Reply #18 on: July 31, 2009, 07:58:52 pm »
they will sit about 12mm further out then the monza's, they will be fine, maybe a little rubbage at the front on the liner screw if you went a bit too low :happy2:
Offline WhiteGTI
  • F-A-S-T
« Reply #19 on: July 31, 2009, 09:04:29 pm »
Cheers Gaz  :happy2: :happy2:
Offline Sunglasses Ron
« Reply #20 on: August 01, 2009, 03:32:32 pm »
Had no problems with mine Chris. Straight on with no issues and have only ever had one issue with rubbing when hard cornering and went down a big dip in the road and only rubbed very slightly on the screwhead that holds the wheel arch liner on..
Offline WhiteGTI
  • F-A-S-T
« Reply #21 on: August 01, 2009, 03:38:00 pm »
Cheers Ben, the problem is that I don't know the ET of these wheels, do you know if its written on the wheel?? I looked today and couldn't find it at all. They aren't sticking out from the arch, so the ET can't be that low, however there is no more room for them to stick out any further!!
Just had them fitted, make a huge difference to the handling of the car.
My build thread is updated!
Cheers for the help all,
Chris.
Offline gazbutS3
« Reply #22 on: August 01, 2009, 03:52:52 pm »
they are probably ET45
