Poll
Hi am having problems with my parking sensors not working I have scanded int and the code is 01327 ecu for parking help j446 no signal no communication   Can any one point me in the right direction plz
Help
1 (100%)
Plz
0 (0%)
Total Members Voted: 1
Author Topic: Mk5 golf fault code help  (Read 2923 times)
Offline Jay030787
« on: April 20, 2013, 09:25:59 am »
 Help
Offline edd666999
  • -Receive: 89
Re: Mk5 golf fault code help
« Reply #1 on: April 20, 2013, 09:31:32 am »
Select "new post" not "post new poll" then you will have a normal thread not a poll
Type_R
« Reply #2 on: April 20, 2013, 09:33:07 am »
Firstly, I think you need to remove the poll, as you have asked a question, not polling for a resuly.
Secondly, you need to scan your car with VCDS to see what the actual error code is.
Thirdly, can you tell us a little about the car, any damage or dirt on any of the sensors?
Fourthly, when you put it into reverse how many beeps do you get, a long one, a normal one or none at all??
Offline Jay030787
« Reply #3 on: April 20, 2013, 03:32:46 pm »
Hi sorry new to all this. Right there is no beep when you put it into reverse only had the car 2 weeks but had all the panels out of the boot and its all there beeper and control box so it's factory fitted not an after market one. Is there any tests I can do to see if I have a feed to the control box ?
Type_R
« Reply #4 on: April 20, 2013, 03:46:12 pm »
What did you use to scan the car, as those codes don't really mean anything. You need a VCDS scan to see exactly what the controller is giving as a fault.
Offline Jay030787
« Reply #5 on: April 20, 2013, 03:53:36 pm »
I did it with snap on solus is there any tests I can do on the control module to see if I have a feed
Type_R
« Reply #6 on: April 20, 2013, 04:21:30 pm »
It sounds like the controller is dead. Not sure how much a new one would be. As I said I would try VCDS through someone local to scan it. No signal from the controller sounds like it is dead!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: April 20, 2013, 04:26:44 pm »
have you checked the fuse (fuse 14, 10A)
if the fuse is ok
then the issue is with the wiring or the module
Cluster and Key coding
Location Great Yarmouth
Offline Jay030787
« Reply #8 on: April 20, 2013, 04:46:12 pm »
Where is the fuse is it in the car or under the bonnet checked all the ones in the car
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #9 on: April 20, 2013, 05:36:31 pm »
The wiring or the module is faulty
fuse for pdc is inside the cabin
Offline Jay030787
« Reply #10 on: April 20, 2013, 05:49:16 pm »
Ok thanks you can anyone tell me which wire at the control box should be live so I can test at the box
