Author Topic: These ok for fitting into my Edition30?  (Read 1477 times)
Offline sanj
  • -Given: 17
« on: April 20, 2013, 12:12:36 pm »
http://item.mobileweb.ebay.co.uk/viewitem?itemId=160780758421&cmd=VIDESC
I have the 3 way front factory speakers and the Alpine wr928 head unit, would I need a amp or should I wait to see how it sounds? :happy2:
Offline biffobear
Re: These ok for fitting into my Edition30?
« Reply #1 on: April 20, 2013, 08:07:25 pm »
Fitted them in mine, I have an amp, sound is great, I have tried different head units and the difference in sound is quite noticable
Offline Squeeguk
« Reply #2 on: April 20, 2013, 08:58:03 pm »
Excellent choice Sanj. If you can, stretch to the Performance range, the P165V33, but with those you would be best off hooking up an amp too. You will always be better off running an amp with speakers like that, having said that, they will be a big difference over stock.
Offline Alexis
« Reply #3 on: April 20, 2013, 11:06:28 pm »
I'm also going to replace the stock speakers with something similar, what type of amp do you people recommend for these?
Offline sanj
  • -Given: 17
« Reply #4 on: April 22, 2013, 06:59:12 pm »
Thank's guy's,before I order a set will these fit without the need for any adaptor's,are they a direct swap?
Offline Squeeguk
« Reply #5 on: April 22, 2013, 08:18:07 pm »
You will need to drill out the main 6.5" speakers as they are riveted to the doors and then fit the new speakers using SAK-3108 adapters. You will then also need to get some mdf adapters made for the mids.
Offline sanj
  • -Given: 17
« Reply #6 on: April 22, 2013, 09:06:36 pm »
Offline Squeeguk
« Reply #7 on: April 22, 2013, 09:11:50 pm »
No worries mate. With regards the rings for the mids, they need to be custom made, those rings you linked to will not work as they are. I made some up today in fact for an install I am doing at the moment. I will be doing a full write up on this install so if you wait a few days, it will be up. Then you can see exactly what is involved, etc.
Offline sanj
  • -Given: 17
« Reply #8 on: April 22, 2013, 09:20:35 pm »
Thank's i'll hold on then as i've no idea! :happy2:
Offline Squeeguk
« Reply #9 on: April 27, 2013, 10:18:16 pm »
Will get to the write up as soon as I get a breather Sanj.
