Author Topic: Anyone logged their MAF Output?  (Read 4697 times)
« on: July 31, 2009, 12:56:17 pm »
According to Revo for the GTi you should see a value around 190-205 g/s at full load (VCDS block 002).
What value are you seeing and could you also state what intake you are using along with your mods.
Ta
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
Re: Anyone logged their MAF Output?
« Reply #1 on: July 31, 2009, 01:22:14 pm »
good question  :happy2:
I'll pester TC and we'll get one K03 and one K04 dataset
Red ED35 5dr DSG
BLOG | BUILD
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #2 on: July 31, 2009, 02:22:35 pm »
Here's some I have captured from mine Edition 30 DSG: -
Config 1: -
Revo Stage 2 + (B9-T6-F9)
Milltek TBE
KMD HPFP
Stock Intake with Pipercross Panel
Peak 248 g/s peak
Config 2: -
Milltek TBE
KMD HPFP
VWR Intake
Peak 237 g/s peak
These where taken on one day apart after the car had been running for at least 30mins. The ambient temp was 1c lower on the test of config 2.
Offline Golfgirl
« Reply #3 on: July 31, 2009, 02:31:38 pm »
I have but can't remember the figures :grin:  I'll ask the boss when he gets home :happy2:
FOR SALE!
« Reply #4 on: July 31, 2009, 05:01:58 pm »
Config 1: -
Milltek TBE
KMD HPFP
Peak 248 g/s peak
Config 2: -
Milltek TBE
KMD HPFP
VWR Intake
Peak 237 g/s peak
Steve, have you had your car with its present mods on a RR?
Just curious as if you use the suggested formula of peak airflow being roughly 0.80 times your horsepower (if you are close to sea level) then your car only has around 300bhp which for a stage 2+ car is unbelievable...   :confused:
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #5 on: July 31, 2009, 07:20:02 pm »
^^^ That's very strange.
When I had the Stage 2+ code put on the car Justin from the TT Shop did some logging and he also got the same peak reading of 248g/s but he also said NeilM's car which had been in the week before had a peak airflow of 249g/s and he had the Evoms on his  :confused:
« Reply #6 on: July 31, 2009, 07:29:24 pm »
...I mentioned this because I've logged a revo stage 2+ GTi  with a k03 and got 224g/s max...
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #7 on: July 31, 2009, 07:43:20 pm »
Maybe I need to get mine on a dyno  :confused:
« Reply #8 on: July 31, 2009, 07:47:55 pm »
Do you have access to VCDS as some request/actual boost and N75 duty logs may help identify a leak
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #9 on: July 31, 2009, 07:52:11 pm »
^^^ Do you know which measuring blocks these come under?
« Reply #10 on: July 31, 2009, 07:59:22 pm »
Off hand no but I'll go check my laptop for you now.
« Reply #11 on: July 31, 2009, 08:03:45 pm »
block 115 for boost and block 118 for Wastegate (N75) Duty Cycle.   :smiley:
Might as well check your CFs on block 020 while you're there.
Offline SteveP
  • -Given: 117
  • -Receive: 340
    • My Project
« Reply #12 on: July 31, 2009, 08:56:49 pm »
Here's the boost and N75 duty cycle  :confused:
Engine Speed -    STAMP   Intake Air Mass -    STAMP   Intake Air - Temperature   N75   STAMP   BP - (specified)   BP - (actual)
 /min       g/s      Ã‚°C    %       mbar    mbar
800   0   3.53   0.05   29   0   0.19   350   1000
840   0.28   3.53   0.33   29   0   0.51   340   1000
800   0.6   3.47   0.65   29   0   0.78   350   1000
840   0.88   3.47   0.92   29   0   1.12   340   1000
800   1.2   3.47   1.25   29   0   1.39   350   1000
800   1.53   3.47   1.58   29   0   1.72   350   1000
800   1.81   3.56   1.86   29   0   2.04   350   1000
800   2.14   3.53   2.19   29   0   2.33   380   1000
760   2.42   3.47   2.47   29   0   2.66   480   1000
880   2.75   4.69   2.8   29   0   2.94   510   1000
720   3.08   6.28   3.13   29   0   3.27   590   1000
640   3.36   6.36   3.41   29   0   3.59   820   1000
880   3.69   7.83   3.73   30   0   3.87   640   1000
960   3.97   8.56   4.01   30   0   4.2   820   1000
1160   4.29   9.94   4.34   29   0   4.48   710   1010
1240   4.62   11.17   4.66   29   0   4.8   710   1010
1320   4.89   12.08   4.94   29   0   5.12   710   1020
1360   5.22   12.28   5.27   29   0   5.4   690   1020
1360   5.5   12.42   5.55   29   0   5.73   360   1030
1280   5.83   6.17   5.87   28   0   6.01   370   1020
1200   6.16   5.5   6.2   28   0   6.34   440   1020
1200   6.44   6.42   6.48   28   0   6.67   450   1010
1120   6.76   6.19   6.81   28   0   6.96   360   1010
960   7.05   5   7.09   28   0   7.28   360   1010
1000   7.38   4.42   7.42   28   0   7.56   420   1010
920   7.7   5.58   7.75   28   0   7.89   390   1010
1080   7.98   3.89   8.03   28   1.6   8.21   1020   1000
1280   8.31   13.5   8.36   29   0.8   8.5   1020   1010
1600   8.59   17.83   8.64   29   0.8   8.83   1050   1030
1640   8.92   25.83   8.97   29   0   9.12   970   1060
1960   9.25   27.25   9.29   29   0   9.44   950   1090
2040   9.53   28.56   9.58   29   0   9.76   620   1100
2120   9.86   15.39   9.9   28   0   10.04   640   1080
1960   10.14   16.89   10.19   28   0   10.38   800   1060
1960   10.47   22.28   10.52   28   0   10.66   820   1070
2000   10.8   20.83   10.85   28   0   10.99   740   1080
2040   11.08   19.36   11.13   28   0   11.31   770   1080
2120   11.41   19.69   11.45   28   0   11.59   840   1080
2200   11.69   24   11.73   28   0   11.92   880   1100
2320   12.01   26.36   12.06   28   0   12.2   920   1110
2520   12.34   30   12.39   28   0.8   12.53   1180   1130
2000   12.63   45.33   12.67   28   0.8   12.86   1190   1230
1840   12.95   40.14   13   29   0   13.14   1000   1260
1880   13.23   30.75   13.28   29   0   13.47   1020   1240
2000   13.56   27.42   13.61   28   0.8   13.75   1090   1210
2160   13.89   31.06   13.94   28   1.2   14.08   1370   1210
2360   14.17   46.14   14.22   28   28.2   14.41   1580   1280
2520   14.5   54.83   14.54   28   35.7   14.69   1610   1380
2760   14.78   62.75   14.83   28   34.1   15.02   1660   1510
2960   15.11   78.61   15.16   29   35.7   15.3   1410   1660
3200   15.44   80.53   15.48   30   16.1   15.63   1300   1630
3360   15.72   57.03   15.77   29   9.8   15.95   1150   1470
2640   16.05   62.14   16.09   28   0   16.23   850   1370
2480   16.33   27   16.38   27   0   16.56   480   1250
2440   16.65   11.39   16.7   27   0   16.85   300   1150
2280   16.98   6.78   17.03   27   0   17.17   290   1090
2080   17.26   6.94   17.31   27   0   17.49   280   1050
1880   17.59   7.25   17.64   27   0   17.77   280   1040
1640   17.87   6.75   17.91   27   0   18.09   270   1030
1400   18.19   5.47   18.23   27   0   18.38   260   1030
1240   18.52   5.17   18.56   27   0   18.71   290   1020
1080   18.8   4.53   18.85   27   0   19.03   340   1020
960   19.13   4.75   19.17   27   0   19.31   360   1010
920   19.41   4.92   19.45   27   0   19.64   400   1010
920   19.73   5   19.78   27   0   19.92   380   1010
800   20.06   4.89   20.11   27   0   20.25   420   1010
840   20.34   4.78   20.39   28   0   20.57   420   1010
840   20.67   5.03   20.72   28   0   20.86   420   1010
840   20.95   4.78   21   28   0   21.18   420   1000
800   21.28   4.97   21.33   28   0   21.47   430   1000
760   21.61   4.94   21.65   28   99.6   21.79   1300   990
880   21.89   14.47   21.94   28   99.6   22.13   1280   1000
1120   22.22   15.83   22.26   28   99.6   22.4   1270   1010
1760   22.5   20.31   22.54   29   99.6   22.73   1480   1030
2120   22.83   36.58   22.88   29   20.4   23.02   1110   1110
2280   23.15   37.92   23.2   29   0   23.34   680   1180
2320   23.44   19.83   23.48   28   0   23.67   910   1140
2400   23.77   29.97   23.81   28   0.8   23.95   1020   1140
2560   24.05   36.03   24.09   28   0.8   24.27   1100   1180
2920   24.37   44.47   24.41   28   0.8   24.54   1210   1250
3360   24.68   63.86   24.73   28   0.8   24.88   1210   1410
3880   24.97   71.14   25.01   28   0.8   25.2   1190   1460
4200   25.29   70.47   25.34   28   0.8   25.48   1080   1460
4560   25.58   67.94   25.63   28   0.8   25.81   1050   1440
4880   25.91   73.56   25.95   27   0.8   26.09   1030   1450
3640   26.23   78.44   26.28   27   0.8   26.42   1100   1390
3240   26.51   53.5   26.56   27   0.8   26.75   1100   1420
3400   26.84   63   26.89   27   0.8   27.03   1060   1450
3480   27.13   56.19   27.17   27   0   27.36   660   1360
3520   27.45   28.25   27.5   27   0   27.64   410   1250
3400   27.78   10.83   27.82   26   0   27.96   310   1140
3360   28.05   9.69   28.09   26   0   28.28   310   1090
3240   28.38   11.17   28.42   26   0   28.56   300   1070
3040   28.65   11.36   28.7   26   0   28.89   300   1050
2800   28.98   10.75   29.03   26   0   29.17   300   1050
2560   29.31   7.03   29.36   26   0   29.5   290   1050
2320   29.59   9.83   29.64   26   0   29.82   290   1050
2120   29.91   8.36   29.96   26   0   30.09   280   1040
1880   30.18   7.47   30.23   26   0   30.42   280   1040
1680   30.51   6.44   30.56   27   0   30.7   280   1030
1440   30.84   5.39   30.89   27   0   31.03   260   1030
1240   31.13   4.47   31.17   27   0   31.36   270   1020
1080   31.45   3.78   31.5   27   0   31.65   340   1020
960   31.73   4.56   31.78   27   0   31.96   350   1010
840   32.06   4.47   32.11   27   0   32.25   420   1010
760   32.39   5.08   32.44   27   0   32.58   460   1010
800   32.67   5.14   32.72   27   0   32.9   440   1010
840   33   5.25   33.05   28   0   33.19   430   1010
840   33.28   4.89   33.33   28   0   33.51   440   1010
800   33.61   5   33.65   28   0   33.8   430   1010
800   33.93   5.14   33.98   28   0   34.13   450   1000
800   34.22   5.06   34.26   28   0   34.45   450   1000
840   34.54   5.36   34.59   28   0   34.73   440   1000
840   34.83   5.14   34.88   28   0   35.06   420   1000
760   35.16   4.97   35.2   28   0   35.34   1300   1000
1080   35.48   12.42   35.53   28   99.6   35.67   1310   1000
1520   35.77   14.25   35.81   28   99.6   36   1440   1000
2000   36.09   28.69   36.14   28   99.6   36.28   1670   1050
2320   36.38   41.06   36.42   28   99.6   36.61   2070   1160
2600   36.7   55.19   36.75   29   43.1   36.89   1380   1300
2960   37.03   68.94   37.08   29   22.7   37.22   1380   1500
3440   37.31   80.83   37.36   29   20   37.54   1400   1620
2520   37.64   83.17   37.69   29   16.1   37.83   1440   1560
2600   37.92   61.22   37.96   29   12.9   38.14   1430   1510
2840   38.23   64.53   38.28   28   11.8   38.42   1440   1500
3080   38.56   70.28   38.6   28   7.8   38.74   1140   1490
3200   38.83   61.19   38.87   28   0   39.06   760   1360
3280   39.15   31.81   39.21   27   0   39.34   520   1250
3280   39.44   19.83   39.49   27   0   39.67   360   1160
3240   39.77   12   39.81   27   0   39.95   330   1110
3240   40.09   12.06   40.14   27   0   40.28   340   1070
3200   40.38   13.14   40.42   27   0   40.61   340   1050
3160   40.7   13.17   40.75   27   0   40.89   340   1060
3160   40.98   13.86   41.03   27   0   41.22   380   1050
3160   41.31   15.78   41.36   27   0   41.5   390   1050
3120   41.64   16.11   41.68   27   0   41.83   400   1050
3120   41.92   16.33   41.97   27   0   42.16   400   1050
3120   42.25   16.36   42.29   27   0   42.44   510   1050
3160   42.53   24.47   42.58   27   0   42.76   610   1060
3160   42.86   27.61   42.9   27   0   43.04   670   1090
3280   43.18   31.31   43.23   27   0   43.38   970   1120
3360   43.46   53.11   43.51   27   0   43.7   880   1270
3440   43.78   56.47   43.83   27   0   43.97   880   1390
3560   44.06   49.22   44.11   27   0   44.3   920   1400
3680   44.39   49.64   44.44   27   0.8   44.58   1060   1420
3800   44.71   65.53   44.76   27   0.8   44.9   1180   1450
4080   45   71.25   45.04   27   60.4   45.23   1900   1470
4360   45.33   132.83   45.38   27   99.6   45.51   2550   1910
4880   45.61   190.03   45.66   28   78.4   45.84   2540   2540
5080   45.93   220.69   45.98   29   84.7   46.13   2520   2560
5480   46.26   222.36   46.31   30   85.1   46.46   2540   2440
5840   46.55   224.53   46.59   30   87.5   46.78   2520   2300
6160   46.88   231.33   46.92   30   99.6   47.06   2470   2190
6560   47.16   231.58   47.21   30   99.6   47.4   2460   2090
4840   47.49   232.67   47.54   31   99.6   47.69   2460   2130
5160   47.82   209.22   47.88   31   88.6   48.02   2540   2470
5320   48.11   219.92   48.15   32   88.2   48.34   2540   2460
5560   48.44   221.69   48.48   32   89   48.63   2540   2420
5680   48.72   231.33   48.76   33   89.8   48.94   2540   2370
5880   49.04   231.47   49.08   33   99.6   49.22   2540   2330
6040   49.36   234.94   49.4   33   99.6   49.54   2490   2230
6240   49.64   232.25   49.69   33   99.6   49.87   2460   2170
6400   49.97   231.81   50.02   34   99.6   50.16   2470   2130
6600   50.26   231.86   50.31   34   99.6   50.5   2470   2090
6240   50.6   234.28   50.65   35   99.6   50.8   2480   2080
5040   50.93   201.75   50.98   35   93.3   51.13   2540   2430
5160   51.22   216.89   51.27   36   89.8   51.45   2540   2510
5280   51.54   220.14   51.59   36   90.2   51.73   2540   2500
5360   51.83   220.81   51.88   36   90.2   52.06   2540   2470
5480   52.15   224.69   52.2   36   91   52.34   2540   2440
5560   52.48   222.75   52.53   36   91.4   52.67   2550   2420
5680   52.76   230.25   52.82   36   92.2   53   2540   2400
5800   53.09   230.81   53.14   37   94.5   53.28   2540   2380
5840   53.38   230.81   53.42   37   99.6   53.61   2530   2330
5960   53.7   231.58   53.75   38   99.6   53.89   2510   2300
6040   54.03   235.08   54.07   38   99.6   54.22   2500   2260
6120   54.31   233.75   54.36   38   99.6   54.54   2490   2230
6200   54.64   234.69   54.69   38   99.6   54.83   2490   2210
6120   54.93   232.81   54.98   38   0   55.16   780   2370
6160   55.26   9.42   55.3   39   0   55.45   300   1520
6120   55.59   10.81   55.64   36   0   55.79   300   1220
6040   55.89   19.81   55.93   35   0   56.12   300   1160
6040   56.22   21.06   56.27   34   0   56.41   300   1130
5880   56.51   21.36   56.56   33   0   56.75   300   1110
5320   56.84   20.97   56.89   33   0   57.03   300   1100
5000   57.17   18.78   57.22   33   0   57.36   300   1080
4640   57.45   17.5   57.5   33   0   57.68   300   1080
4560   57.77   16.78   57.81   33   0   57.95   300   1080
4480   58.04   16.28   58.09   33   0   58.28   300   1080
4440   58.38   16.5   58.42   32   0   58.56   300   1080
4400   58.7   16.61   58.75   32   0   58.89   300   1090
4120   58.98   15.61   59.03   32   0   59.21   300   1090
3960   59.31   15.31   59.36   32   0   59.5   300   1090
3760   59.59   14.81   59.64   31   0   59.83   300   1090
3640   59.92   13.69   59.97   31   0   60.11   300   1090
3600   60.24   13.06   60.29   31   0   60.44   300   1090
3560   60.53   12.53   60.58   31   0   60.76   300   1080
3680   60.86   12.89   60.9   31   0   61.04   810   1050
3560   61.14   47.61   61.18   31   0   61.37   510   1130
3520   61.46   22.86   61.5   31   0   61.64   410   1110
3520   61.78   17.92   61.83   31   0   61.97   580   1080
3520   62.06   29   62.11   30   0   62.29   690   1120
3520   62.39   36.11   62.44   31   0   62.58   770   1170
3480   62.67   40.47   62.72   31   0   62.9   840   1230
3480   63   46.97   63.04   31   0   63.19   840   1300
3480   63.32   42.86   63.38   31   0   63.51   840   1340
3480   63.61   41.81   63.65   31   0   63.84   740   1340
3480   63.94   33.67   63.99   30   0   64.13   560   1320
3440   64.22   22.31   64.26   30   0   64.45   310   1210
3440   64.54   8.53   64.59   30   0   64.73   310   1130
3400   64.87   10.31   64.92   30   0   65.06   310   1080
3400   65.16   11.33   65.2   30   0   65.39   310   1060
3360   65.48   11.75   65.53   30   0   65.67   310   1050
3320   65.77   11.81   65.81   30   0   66   310   1050
3320   66.09   11.78   66.14   30   0   66.28   310   1050
3280   66.42   9.86   66.47   30   0   66.61   310   1060
3280   66.7   11.67   66.75   30   0   66.93   310   1060
3240   67.03   11.94   67.08   30   0   67.21   310   1060
3240   67.31   11.86   67.36   30   0   67.54   310   1070
3200   67.64   11.78   67.68   30   0   67.82   310   1060
3200   67.96   11.39   68   30   0   68.14   310   1070
3160   68.23   11.47   68.28   29   0   68.46   300   1060
3160   68.56   11.56   68.61   29   0   68.75   300   1070
3160   68.84   11.17   68.89   29   0   69.07   300   1060
3160   69.17   10.67   69.21   29   0   69.36   500   1060
3120   69.49   22.5   69.54   29   0   69.69   510   1070
3120   69.78   21.72   69.83   30   0   70.01   490   1080
3120   70.11   20.75   70.15   30   0   70.3   470   1090
3120   70.39   19.56   70.44   30   0   70.62   450   1090
2280   147.79   7.64   147.51   27   0   147.65   290   1040
2080   148.07   7.03   147.84   27   0   147.98   280   1030
1880   148.4   6.25   148.12   27   0   148.31   280   1030
1760   148.68   5.64   148.45   28   0   148.59   270   1030
1720   149   5.58   148.73   28   0   148.91   270   1020
1680   149.32   5.36   149.04   28   0   149.18   270   1020
1720   149.61   9.67   149.37   28   0   149.51   430   1020
1680   149.94   10.19   149.65   28   0   149.84   460   1020
1720   150.21   10.36   149.98   28   0   150.12   490   1020
1720   150.54   13.89   150.26   28   0   150.45   640   1020
1880   150.87   34.69   150.59   29   99.6   150.73   1690   1000
1920   151.15   40.42   150.92   29   99.6   151.06   1670   1060
2120   151.48   49.97   151.2   29   99.6   151.39   1860   1160
2320   151.76   60   151.52   30   99.6   151.67   2170   1270
2560   152.09   77.81   151.81   30   99.6   151.99   2330   1450
2840   152.41   99.39   152.14   30   99.6   152.27   2420   1650
3320   152.68   149.61   152.46   30   99.6   152.59   2450   1970
3600   153   131.69   152.73   30   42.7   152.91   2140   2490
3960   153.28   133.08   153.04   30   36.9   153.18   2220   2070
4280   153.59   150.94   153.32   30   41.6   153.5   2120   1890
4520   153.92   189.58   153.64   29   54.9   153.78   2300   2050
5040   154.2   213.25   153.96   30   67.1   154.11   2380   2310
5320   154.53   226.08   154.24   30   69   154.43   2540   2440
5680   154.81   227.03   154.57   30   73.7   154.72   2540   2370
6240   155.14   235.08   154.86   30   92.2   155.05   2480   2210
6440   155.48   234.42   155.19   31   99.6   155.34   2470   2140
4840   155.76   214.56   155.53   31   99.6   155.67   2550   2250
5080   156.09   219.92   155.81   32   87.5   155.99   2540   2510
5240   156.37   221.92   156.14   32   88.6   156.28   2540   2490
5520   156.69   229.03   156.42   32   88.6   156.6   2540   2430
5680   157.01   232.67   156.74   33   89   156.88   2540   2410
5880   157.3   234.03   157.06   33   93.3   157.2   2520   2340
6080   157.62   237.67   157.34   33   99.6   157.52   2480   2260
6280   157.91   235.5   157.67   34   99.6   157.81   2460   2200
6520   158.23   235.36   157.96   34   99.6   158.14   2470   2150
6560   158.57   229.03   158.28   35   99.6   158.43   2470   2120
5000   158.86   216.33   158.62   35   99.6   158.76   2550   2370
5120   159.17   222.61   158.91   36   89.4   159.08   2540   2530
5200   159.45   222.92   159.22   36   89.4   159.36   2550   2520
5320   159.78   222.14   159.49   36   89.8   159.69   2540   2500
5440   160.11   227.03   159.82   36   91.4   159.96   2540   2470
5560   160.39   233.08   160.15   36   94.5   160.29   2540   2450
5640   160.7   231.19   160.43   36   98   160.62   2540   2420
5760   160.99   233.06   160.75   37   99.6   160.89   2550   2390
5840   161.31   232.14   161.03   37   99.6   161.21   2520   2360
6000   161.63   235.08   161.36   38   99.6   161.49   2510   2320
6040   161.93   235.22   161.69   38   99.6   161.83   2490   2260
6200   162.26   234.17   161.98   38   99.6   162.17   2490   2240
6280   162.56   235.31   162.31   39   99.6   162.46   2490   2230
6320   162.89   234.94   162.61   39   99.6   162.79   2490   2210
6240   163.23   12.56   162.94   39   29   163.09   770   2490
6120   163.53   11.78   163.28   39   0   163.43   300   1430
5920   163.85   19.17   163.57   36   0   163.76   300   1210
5400   164.13   18.58   163.89   35   0   164.03   300   1150
4960   164.45   16.58   164.17   35   0   164.36   300   1120
4560   164.77   16.11   164.49   35   0   164.64   300   1090
4320   165.06   15.67   164.82   34   0   164.96   300   1080
4280   165.39   16.5   165.11   34   0   165.29   300   1080
4200   165.67   15.19   165.43   34   0   165.57   300   1090
4080   165.98   14.78   165.71   33   0   165.89   300   1090
4000   166.3   14.78   166.02   33   0   166.16   300   1090
3960   166.59   14.25   166.36   33   0   166.49   300   1090
4000   166.91   72.64   166.64   33   0   166.82   1380   1090
4000   167.18   116.72   166.96   33   99.6   167.09   2530   1240
4040   167.5   179.58   167.23   33   99.6   167.41   2550   1910
4120   167.82   204.89   167.54   33   63.5   167.68   2550   2560
4240   168.11   200.86   167.87   35   72.2   168.01   2550   2780
4240   168.43   201.44   168.15   35   67.5   168.33   2540   2760
4320   168.71   180.28   168.48   35   63.5   168.62   2530   2620
4400   169.05   196.64   168.76   36   62.4   168.95   2530   2520
4480   169.37   193.64   169.09   36   62.7   169.23   2520   2490
4520   169.65   198.19   169.41   36   63.1   169.56   2520   2500
4600   169.98   199.14   169.7   36   63.1   169.89   2500   2480
4680   170.26   201.44   170.02   36   63.9   170.17   2500   2470
4720   170.59   204.64   170.31   36   63.9   170.49   2490   2490
4680   170.92   87.03   170.64   36   59.6   170.77   1840   2470
4000   171.2   5.28   170.96   36   0   171.11   530   1800
3960   171.53   8.11   171.24   35   0   171.43   300   1280
3960   171.81   11.94   171.57   33   0   171.71   300   1160
3920   172.14   13.36   171.86   33   0   172.04   300   1100
3960   172.46   13.75   172.19   33   0   172.33   300   1080
3880   172.74   14.14   172.51   33   0   172.65   300   1070
3880   173.07   14.03   172.79   33   0   172.97   300   1070
3880   173.36   14.33   173.13   33   0   173.26   300   1080
3840   173.68   14.08   173.4   33   0   173.59   300   1090
3840   174.01   13.53   173.73   33   0   173.87   300   1090
3800   174.29   13.89   174.06   33   0   174.2   300   1090
3800   174.62   13.36   174.34   32   0   174.52   300   1090
3760   174.9   13.22   174.67   32   0   174.81   300   1090
3760   175.23   13.36   174.95   32   0   175.14   300   1090
3720   175.55   13.64   175.28   32   0   175.42   300   1090
3720   175.82   13.39   175.6   32   0   175.73   300   1090
3680   176.15   13.36   175.87   32   0   176.05   300   1090
3640   176.43   13.25   176.2   32   0   176.34   300   1090
3640   176.76   13.11   176.48   32   0   176.66   300   1090
3640   177.08   13.61   176.81   32   0   176.95   300   1090
I can see there some differences but I am not what's normal  :confused:
Offline neg
  • gone old skool
« Reply #13 on: July 31, 2009, 10:18:35 pm »
K03 you should  get around the 200's,  K04 you will get 250's (once remapped on both counts)
Offline keith
« Reply #14 on: July 31, 2009, 10:25:26 pm »
if someone pm's me with a how to i will log my race and pump runs with hffp,s3 i/c, dbilas. NO tbe though its standard. i have vcds but lost my user guide when my hard drive bombed.
