Author Topic: Any ideas please - car juddering and misfiring vcds codes  (Read 3834 times)
Offline Lean
  • DSG +..
« on: April 21, 2013, 08:48:41 pm »
I've replaced 4x coil packs and they weren't the problem I'm thinking it is the injectors having read other posts/threads does anyone have any ideas please. Cheers
000768 - Random/Multiple Cylinder Misfire Detected
               P0300 - 001 -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100001
                    Fault Priority: 0
                    Fault Frequency: 70
                    Mileage: 166807 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 04:42:14
             Freeze Frame:
                    RPM: 1830 /min
                    Load: 73.3 %
                    Speed: 49.0 km/h
                    Temperature: 75.0°C
                    Temperature: 11.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.351 V
000770 - Cylinder 2
               P0302 - 001 - Misfire Detected - MIL ON
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 70
                    Mileage: 166807 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 04:42:17
             Freeze Frame:
                    RPM: 1830 /min
                    Load: 73.3 %
                    Speed: 49.0 km/h
                    Temperature: 75.0°C
                    Temperature: 11.0°C
                    Voltage: 14.351 V
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 5
                    Mileage: 166785 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 12:48:27
             Freeze Frame:
                    RPM: 850 /min
                    Load: 16.1 %
                    Speed: 0.0 km/h
                    Temperature: 79.0°C
                    Temperature: 38.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.097 V
005699 - Please check DTC Memory of Electric Load Controller
               P1643 - 001 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 168243 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:17:23
             Freeze Frame:
                    RPM: 1114 /min
                    Load: 65.9 %
                    Speed: 0.0 km/h
                    Temperature: 88.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.192 V
000772 - Cylinder 4
               P0304 - 002 - Misfire Detected - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Mileage: 169004 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:29:10
             Freeze Frame:
                    RPM: 4355 /min
                    Load: 34.1 %
                    Speed: 85.0 km/h
                    Temperature: 81.0°C
                    Temperature: 21.0°C
                    Voltage: 13.970 V
000771 - Cylinder 3
               P0303 - 002 - Misfire Detected - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 169515 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:05:09
             Freeze Frame:
                    RPM: 767 /min
                    Load: 14.9 %
                    Speed: 0.0 km/h
                    Temperature: 82.0°C
                    Temperature: 32.0°C
                    Voltage: 13.843 V
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 043 C    HW: 02E 927 770 AE
   Component: GSG DSG         070 1111
   Revision: 04507000    Serial number: 00000601300402
   Coding: 0000020
   Shop #: WSC 01279 785 00200
   VCID: 1409759737542ABE3AB
Offline rich golf gti mk5
Re: Any ideas please - car juddering and misfiring vcds codes
« Reply #1 on: April 22, 2013, 12:28:00 pm »
Av u tryed plugs ?
Offline Lean
  • DSG +..
« Reply #2 on: April 22, 2013, 11:46:08 pm »
Yes mate had a major service coil pack, plugs replaced but still the problem remains.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=bjhabsebhijbmdohu01rnnvhd1&/topic,19740.0.html
« Reply #3 on: April 23, 2013, 12:34:26 am »
It could be injectors.... do you have the facility to change them yourself?
Offline Rob.
« Reply #4 on: April 23, 2013, 09:56:26 am »
Injector loom?
Offline omeydz
  • -Receive: 50
« Reply #5 on: April 23, 2013, 11:24:58 am »
Yeah Id point to injectors.
Try swapping the suspect one with another fault free cylinder's injector and see if the fault migrates. If it doesnt, then maybe loom?
Injectors are quite dear (more than coilpacks!), I dont know how useful injector cleaner fuel additives are?
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
northyracing
« Reply #6 on: April 25, 2013, 07:46:08 pm »
I'm having the same problem with mine judders at low speed and misfire on cylinder 2 I changed plugs and coils and still the same
Saintsteve
« Reply #7 on: April 25, 2013, 08:11:58 pm »
Tried that on mine , and doesn't work..
Another failing injector by the sound of it. Very common by all accounts..Injectors each are about £110 +vat and budget a couple hours labour in a reputable garage.
I've tried various cleaning methods but not enough to cure it full stop , problem reoccurred .Its either that or gummed up intake valve not allowing enough air into the cylinder that's effected.
« Last Edit: April 25, 2013, 08:14:04 pm by Saintsteve »
Offline Lean
  • DSG +..
« Reply #8 on: April 25, 2013, 09:29:09 pm »
Thanks guys I don't have the facility to change them myself but booked into the garage in a couple of weeks have mentioned the report so will have to pay for another one from garage then they'll ring my extended warranty company.. As long as they believe the report points to injectors.
Offline Kavichauhan
« Reply #9 on: April 25, 2013, 10:45:44 pm »
Hi there, I'm not sure if much of this will make any sense, but may be of some help...
I have just bought a mk5 GTi from an independent dealer, he said he had the car in as a part exchange and was now selling it (as they do).
He was upfront and honest with me, and told me that when he took the car in it was misfiring and and so he replaced plugs, leads, and coil pack but still didn't work. He then changed the fuel pump, and apparently it was this that was causing the problem. Might be worth looking at?
the car is under warranty and has the ultimate warranty cover with autoprotect so if I get any other problems, I will be on the phone to them!
2001 MK4 GT TDi 130 pd Silver
2006 MK5 GTi DSG Black
Saintsteve
« Reply #10 on: April 26, 2013, 08:22:15 pm »
My fuel trims are too high.. So my guess is with one injector not firing, the ecu is overcompensating .
JKM have called to say they agree, injector 4 looks as if its the fault.Car will be ready early next week.
Offline holepunch
« Reply #11 on: April 28, 2013, 08:20:42 pm »
My 06 GTI is also suffering from poor cold starts and I suspect it's the fuel pump that primes when you open the door. Can you confirm which fuel pump your garage changed? It be great if you could provide part numbers and prices.
