Author Topic: CMOS 300 kenwood reverse camera  (Read 2554 times)
Offline LondonGT
« on: April 22, 2013, 03:40:16 pm »
Has anyone fitted one of these to a mk5?
Long story, I need to get a reverse camera fitted, like the idea of the features it offers but can't see how one gets fitted without drilling holes?
Offline skard
  • -Receive: 245
Re: CMOS 300 kenwood reverse camera
« Reply #1 on: April 22, 2013, 05:57:25 pm »
I had number plate cameras on my old car, no holes to drill and replaces a number plate light unit
Offline LondonGT
« Reply #2 on: April 22, 2013, 07:55:13 pm »
Can you remember what the brand was and if it was any good? I've seen lots of those but very different ones. I like the functionality of the Kenwood one, but not enough to chop up the bumper. Thanks!
Offline skard
  • -Receive: 245
« Reply #3 on: April 22, 2013, 08:10:35 pm »
Just a Chinese one on ebay. I guess the Kenwood is overpriced, plus CMOS is bad compared to CCD.
They're ok for a while, eventually the perspex will get stone chipped and either marr the view or let in condensation. The LED lights usually die after a year, and some come with stupid and unusable reference lines.
But for £10-15 I accepted that.
Offline LondonGT
« Reply #4 on: April 22, 2013, 08:16:47 pm »
that's what is confusing me. i like the wide angle view of the kenwood, not bothered about the park help. I don't think i need night vision....i have reverse lights.
180 quid seems a bit steep though, esp as that seems to include a hole in the bumper. I've looked at the integrated number plate light ones, can live with that, but would ideally like to not have to swap out every few years.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #5 on: April 22, 2013, 08:51:48 pm »
Got my VW camera for about £120ish including loom and brackets but will need to dremel my bumper!
Offline LondonGT
« Reply #6 on: April 22, 2013, 09:36:06 pm »
Cheers for the tip on CCD, hadn't spotted the resolution difference.
What's the VW one you got? The only one I could see was in the badge and only works with the original kit. I have the dnx520 so not sure that's an option for me.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #7 on: April 22, 2013, 09:48:24 pm »
Its one that sits in the bumper so you have got to dremel it! Not sure if it will work with your headunit though!
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #8 on: April 23, 2013, 08:30:22 am »
Im after the one that sits in the bumper too, I think its the scirocco one. However a member from the forum said that it might be a bit too low.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #9 on: April 23, 2013, 10:39:32 am »
it will be low as it points downward.
have seen this one, which is a vertical
http://www.carsystems.pl/vw-amarok-2h0-rear-highline-camera-kit,id642.html
I think the vertical mount would work with the scirocco camera
Cluster and Key coding
Location Great Yarmouth
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #10 on: April 23, 2013, 10:44:10 am »
That seems better. But at that price wouldnt it be better to get the badge camera instead?
Raz
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: April 23, 2013, 10:54:32 am »
Raz
read what I wrote
I said find the holder and use the scirocco camera
The part number for the vertical mount is 2H0 980 561 & 2H0 980 554
comes in at under £10
« Last Edit: April 23, 2013, 10:57:40 am by Eddie-NL »
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #12 on: April 23, 2013, 01:24:27 pm »
Iv ordered 3w0 807 210 B and 3w0 807 151. Might need to re-order the bits!
Offline LondonGT
« Reply #13 on: April 23, 2013, 03:07:18 pm »
So that one you need to screw into the bumper too?
I found a ccd one for about 70 quid that fits in the plate light socket. Might just go for that. I like the kenwood but for the effort and cost it's not great.
One thing I am unable to find is any pictures on mark 5s, for any cameras.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 73
« Reply #14 on: April 23, 2013, 04:46:25 pm »
The parts i ordered put the camera out at a 45 degree angle so the bumper needs to be cut in the centre between the 2 number plate lights to fit it in
