Author Topic: Rear end knocking  (Read 1473 times)
Offline waynos
Rear end knocking
« on: April 23, 2013, 07:32:40 am »
Hey guys ive got an 05 gti lowered with fk coilovers on 18inch 3sdm wheels. Had this set up for roughly a year. In the past few months the car has developed an annoying knocking over bumps. Its not overly loud but i can tell its there. I changed the anti roll bar links and trailing arm bushes ( pain in the arse) last weekend but the noise is still there. The back end also feels a little twitchy over uneven ground. Any ideas what it could be? (Its not the parcel shelf rubbers! As ive driven with the shelf out :)
Offline xjay1337
  • -Receive: 377
Re: Rear end knocking
« Reply #1 on: April 23, 2013, 09:07:02 am »
Top mounts on the rear?
Offline stuartDLK
« Reply #2 on: April 23, 2013, 10:08:46 am »
Have you checked to see if the rear shocks havent gone? I had the same problem and thats what it was. FK street coilovers always have this problem. Hope that helps you out!
Offline percy
« Reply #3 on: April 23, 2013, 03:06:07 pm »
It will be the rear shocks I had the the same problem and tried two sets of fk shocks then just used my old oem shocks and that sorted the problem mate
Offline webby888
« Reply #4 on: April 23, 2013, 05:34:13 pm »
do the oem shocks work well with the back lowered down?
iv got the knocks too and was thinking it could be the fk shocks being rubbish
Offline BlackGTI
« Reply #5 on: April 23, 2013, 09:01:58 pm »
Could just be the drop links, this was my problem with rear end knocking noise over bumps.
Hope this helps
Offline DanielF
« Reply #6 on: April 24, 2013, 07:31:52 am »
Had same problem mate changed drop links and anti roll bar still was doing it so swapped the shocks back to the standard ones and it's been fine and mines been fine lowered on standard shocks.
Offline waynos
« Reply #7 on: April 24, 2013, 07:37:01 am »
Cheers for the replys guys, its deffo not the drop links as ive put brand new vw parts on last weekend. Ill try the original shocks this weekend and report back!
Offline ConorF
« Reply #8 on: April 24, 2013, 10:03:40 am »
Have this myself in my jetta, im thinking droplinks or shocks too  :ashamed:
Offline waynos
« Reply #9 on: May 04, 2013, 11:46:33 pm »
Swapped back to the original gti shocks, knocking noise is gone and it seems to ride better on the fk springs. I wont be buying fk again thats for sure
