Author Topic: Air-con issue  (Read 1748 times)
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Air-con issue
« on: April 24, 2013, 07:50:39 am »
My Air-con on my GTI which has duel climate control isn't very cold at all or not sure if its even working, could this be a case of re-gassing or could if be something worse?
GTI Pirelli - Reflex Silver - 5dr - 58 - B12 Sportline kit!
Sold ~ GTI - Mk5 - Pearl Black -  Bluefin - 3dr - 08
Offline PaulR32
Re: Air-con issue
« Reply #1 on: April 24, 2013, 10:01:04 am »
Try a leak test and re-gas first chances are if it's not been done for a while that'll sort it.
Offline PaulR32
Re: Air-con issue
« Reply #2 on: April 24, 2013, 10:03:47 am »
Forgot to say i think you should be able to hear it turn on or off when you press the Eco or air con button you will prob hear the engine revs change
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Re: Air-con issue
« Reply #3 on: April 24, 2013, 10:06:59 am »
No I don't think it has. Just found a garage near me is doing £40 for air-con services though May, but not sure what a service would consist of would that be leak test and re-gas? I'll go have a play with the air-con button I don't have the Eco button.
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Re: Air-con issue
« Reply #4 on: April 24, 2013, 03:24:37 pm »
Just popped into the garage, apparently the belt still works but the revs dont drop, so he's going to re-gas it Friday and go from there.  :happy2:
Offline Kalpsn2000
  • -Receive: 56
Re: Air-con issue
« Reply #5 on: April 24, 2013, 03:46:51 pm »
Last summer mine was not really blowing cold air so took it in for an air con service (which was included in my service plan) and that sorted it.
I'm assuming the service includes re-gassing it, so that could sort your problem :happy2:
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Re: Air-con issue
« Reply #6 on: April 24, 2013, 03:54:41 pm »
He wasn't exactly sure but he's going to re-gas the system then fingers crossed that will sort it.
Offline Klausy
Re: Air-con issue
« Reply #7 on: April 27, 2013, 08:27:02 am »
How did you get on with your air con issue ?
Offline TomGTI
  • -Given: 17
  • PIRELLI EDITION
Re: Air-con issue
« Reply #8 on: April 27, 2013, 09:09:59 am »
Yes i had it re-gassed and checked yesterday morning and there was no leaks in the system but when we tried it with the air-con on it didn't feel ice cold but we think that's because it was cold yesterday, so the sun needs to come out to really see.
He said every thing was running right and no error codes so hopefully it'll be fine.
He also gave me a quote for some eibach sport line springs and for the Diverter valve to be replaced, he wasn't keen on removing the precat though.   :driver: :party:
