Author Topic: MKV Hella Xenon-Look and HID Kit Install (Picture heavy)  (Read 53395 times)
Offline D_Philli_82
Re: MKV Hella Xenon-Look and HID Kit Install (Picture heavy)
« Reply #75 on: November 14, 2014, 09:34:54 am »
The October shipment has been delayed, looks like it won't come in till at least December!!! :scared:
build oem :) cheaper the replicas  :driver:
Replicas are £200 :wink:
MK5 1.9TDI 150Bhp
Offline reaper7881
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,68492
« Reply #76 on: November 14, 2014, 10:44:32 pm »
Just one thing to watch out for
The drivers side headlight and the wiper motor have the same grounding point on my car, im guessing the spike in voltage when powering up/down the hids blew it
I had to run a new grounding cable for the motor to stop it happening again
Has anyone else blown their front wiper motor yet. :scared:
54 MK5 Golf 1.9tdi 3dr SMD Full Interior and Speedo Conversion, GTi Highline , Flat Bottom Wheel, ED30 Rear lights
Offline D_Philli_82
« Reply #77 on: November 15, 2014, 09:05:06 pm »
Just program Xenon without shutters with VCDS...problem solved...!!
MK5 1.9TDI 150Bhp
Offline Stamanatic
« Reply #78 on: November 21, 2014, 12:03:28 pm »
Can anyone post here once Depo lights are back in stock? eurowagensltd on ebay said they don't even know when they'll be getting them back in.
Offline mtj2k
  • 1.4 TSi GT
« Reply #79 on: December 03, 2014, 04:05:29 pm »
And make sure you only use the 35W kits and not the 55W ones.. Watt... what??
Offline akbarirfan
  • -Given: 81
Offline JC88
« Reply #81 on: February 20, 2015, 09:26:08 pm »
Hey sorry to post on an old thread but came across this and had a (likely dumb) question which I hope someone can help with. If you fit a HID kit for the main dipped beam; when you use the full beam do you still have a standard bulb fitted?  :confused:
« Last Edit: February 20, 2015, 09:28:29 pm by JC88 »
Offline D_Philli_82
« Reply #82 on: February 21, 2015, 07:02:38 am »
Yes - Osram Nightbreaker ftw  :happy2:
MK5 1.9TDI 150Bhp
Offline bartholomewdj
« Reply #83 on: February 21, 2015, 02:21:51 pm »
Any up to date links for any set of xenons that won't require the 6 o clock mod? Please :)
Offline shaunnorris7
  • -Given: 18
  • 2008 GT TDI
« Reply #84 on: February 21, 2015, 09:17:46 pm »
Glad I found this as I've been watching the depo one on ebay for a while now. I even made another thread asking if they were any good and several people confirmed they were and there was no mention of this 6 o clock mod.
So can someone confirm if the depo's do or don't require this mod?
Offline Sixteen
« Reply #85 on: February 25, 2015, 11:51:27 pm »
Does anyone know if the Depo Xenon look headlights will work with the coming home/leaving function?
Also are they able to be programmed through Vag-Com to enable US indicators as DRL's? From the photos I've seen the sidelights are next to the indicator, rather than in the main beam?
Very tempted by the Depo's as the Hella's are discontinued and proving impossible to find new!
Offline akbarirfan
  • -Given: 81
« Reply #86 on: February 26, 2015, 10:40:55 am »
I have the Depo's and coming/leaving home lights still work (with HID kit).
US Sidelights should work too - it's just coding related, as is the above mate.
Hope that helps.
I bought from here - cheapest I could find:
http://www.body-kit.co.uk/product.php/14596/0/vw-golf-5-03-09-black-inner-dome-projector-headlights
Offline Sixteen
« Reply #87 on: February 26, 2015, 11:04:52 am »
Hope that helps.
Perfect! Thanks for the info and link.
Are you happy with the quality of yours?
Also, the sidelights are definitely in the bottom of the headlight, next to the indicator, as per OEM Xenon's?
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #88 on: February 26, 2015, 11:09:48 am »
the sidelights are next to the indicator just like oem
Offline Sixteen
« Reply #89 on: February 26, 2015, 11:11:46 am »
Perfect, thanks a lot!  :happy2:
